ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti
lock brake system light comes up when there is issue with car brake systems. It
can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly.
Your vehicles brake system needs inspection.
To
troubleshoot these issues, I suggest you to refer the help links provided below.
There are direct links with accurate solution, for these specific issues.
Click
the link below and follow the procedure: ------
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS
light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control
Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
