Question about Samsung S860 Digital Camera
Time setting I have Samsung S860. I would like to know how to set the time. I can only change the time zone but not the clock. TQ
    Problem Solver:
  • 14 Answers
From the display screen that shows the time zone, use the 5 function button (bottom part of wheel) to move down to the field showing the time.
Cllick the menu/ok button
Use the up down button to move hour up or down; use the left right button to move to the minute field; again up down to change minutes
when done hit the menu/ok button
Posted on Jan 08, 2009
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
Apr 08, 2016 | Emerson Smart Set Alarm AM/FM Clock Radio...
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
IMPORTANT: The first time you connect your new SmartSet® clock radio to
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
display to your own zone. You only do this one time and the SmartSet® will remember
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
Oct 03, 2013 | H.H. Scott SCR120 Clock Radio
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
May 02, 2011 | Samsung B5722 Cell Phone
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Apr 27, 2009 | Emerson Smartset Clock Radio
I cannot change the time on my samsung cingular phone
Cell phones set their time by the servers run by the carrier(s) which is set according to atomic clocks. So there is no way to change the time.
However, depending on the phone model/program, you may be able to change a world clock time zone to show the time in that region.
Mar 23, 2009 | Samsung Cell Phones
My over the air channel list program times are 1 hour behind.
I've just sorted the problem on my set , Samsung UE40S6300UXXU, L.E.D.
Enter, "menu"/system//time/clock/......make sure "clock mode" is set to "Auto" and scroll down to "Time Zone" make sure time zone is set to manual, go down to "GMT" and set it to GMT+1 and the job is done. Hope this helps
Mar 14, 2009 | Samsung LN46A630 LCD TV
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Nov 04, 2008 | Emerson Smartset Clock Radio
Why won't it automatically set time?
Sorry it took so long to give you a answer for the problem.I hope this information help you with your problem.Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Oct 21, 2008 | Emerson Smartset Clock Radio
Samsung S860 Digital Camera Logo
57 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
