Question about Microsoft Windows XP Professional
Chkdsk gets stuck for windows XP on restarting
The chkdsk runs on my C: drive
and it gets stuck at 28 % complete.
then i when i restarted again ...i find sort index ...mesage and it gets stuck
  • 36 Answers
Try running these two free programs, Diskcheckup and SmartDefrag. (Just copy the addresses here and paste into your address bar.)
Diskcheckup reads your hard drives and tells you if there are errors, or it reads "OK" in a wide variety of categories. http://www.passmark.com/products/diskcheckup.htm
Once that is done, download and run SmartDefrag. This program, also free, will constantly defrag your system while you are working, but will not interfere with what you are doing. It will also mark any bad areas on your drives to be avoided by the system.
http://www.download.com/Smart-Defrag/3000-2094_4-10759533.html
Posted on Jan 02, 2009
I am running on limited diagnostic ability with no recovery disc. when iran chkdsk /f /r from c prompt it has stayed atuck at12% complete for laat 14 hours
I have run chkdsk /f (which is check disk fix) and I have run chkdsk /r (check disk repair) but I have never heard of trying both switches at the same time. I suggest powering off the machine (hold down power button) than restarting and running chkdsk /f first and if you still have issues run chkdsk /r which is a more in depth scan which can take a couple of hours depending on the size of the drive but never 15 hours in my experience.
Mar 01, 2013 | Computers & Internet
I am running Windows XP Home SP3. When I try to run chkdsk from command promt, I type "Y" when asked if I want it to run on next startup, but get "Windows cannot end this program" and...
When you type "Y" then press enter, then type "exit" and press enter again.
The CHKDSK command on it's own will do nothing to correct any errors on the HDD. You need to qualify what you want CHKDSK to do.
Here is a list of parameters. eg. CHKDSK /f fixes any error found. Note there is a space between K and /
Dec 28, 2010 | Compaq Computers & Internet
The problem I'm experience with my computer start when a blue sceen appears. The statement states: A problem has been dected and windows has been shut down to prevent damage to my computer. If this...
If you are running Windows XP, the boot to the XP CD, press R when prompted to access the Recovery Console, then run the command CHKDSK /R at the C:\windows\system32\ prompt
If you get indications of recovering lost allocation units, then the disk surface of the HDD is likely bad and the HDD will need to be replaced.
If running Windows Vista or Windows 7, boot to the Windows DVD and select REPAIR MY COMPUTER
Dec 23, 2010 | Dell Computers & Internet
My ata 40 gig hdd after installing xp on aformatted drive.every time i run chkdsk it says i have problems that chkdsk can fix,but never dos.
Click start and run
type cmd and press enter
type the following line replacing z with your yor har drive letter
chkdsk z: /f/r/x
you should get a message saying it will check on the next system restart, say Y, then restart your system
When it boots up just before it goes into windows it will check and repair.
Sep 21, 2010 | Computers & Internet
My xp pro os wont boot after running chkdisk at startup.. It checks the disk says ''clean'' then acts like it is going to boot up windows but just hangs there indefinitely .. tried safe mode and it hands...
Open XP in safe mode with command prompt.
Open a command window (start/run type cmd in the box then enter) and you will get the following.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
You will then have a flasihg curser after
C:\Documents and Settings\PC name>
Type
CHKDSK /f /r
You will then get
C:\Documents and Settings\PC name>chkdsk /f /r
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N) y
This volume will be checked the next time the system restarts.
Type exit and restart.
make sure there is a space between each / and the previos word/command
The /f and /r do the following
/f: Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer.
/r: Locates bad sectors and recovers readable information. Again the disk must be locked.
Jul 30, 2010 | Microsoft Windows XP Professional SP3 Full...
Cannot boot on any mode.
get a bootable xp cd boot from cd after booting press r key on the screen u get now xp will start in recovery console now login on it after type the command chkdsk and after completion chkdsk /p after that chkdsk /r exit recovery console restart pc if it doesnt work ur ram module has some problem
Jul 10, 2010 | Microsoft Windows XP Professional for PC
I have done a system recovery, it reinstalls and requests that I restart, after the restart it does more install and freezes, it never completes.
It happence Due to File Curreption or Mismatched System Files...
Put your Bootable Windows XP CD in your CD-Drive/DVD-Drive..
Boot from CD and Select Repair Windows XP...
Select your Windows Installation Drive to Login
Run Some Command From Restore Command Prompt
-- X: is your Windows XP Home Drive
X:\chkdsk /f /r
NEXT
X:\fixmbr
X:\fixboot c:
Restart your System ... Open RUN Dialogue Box from START Menu
Type this Command
Run --> "SFC /F /R" <Press Enter> Paste Without Quotes ..
Wait Until Complete System Check ,then Restart your System
If you want more Usefull Methods Visit this ....
http://www.webtree.ca/windowsxp/repair_xp.htm#How%20to%20Repair%20the%20Boot%20Sector:
Feb 19, 2010 | Microsoft Windows XP Media Centre 2005 for...
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
I have a Dell system with microsoft windows XP. The last 2 days I have gotten a message that a file is corrupt and unreadable and to run a chkdsk utility. I have tried to on two fronts but it refuses to...
use this one:
chkdsk /r
box will come up saying your drive is locked.
Type "Y" for yes. press enter.
Restart the computer and let the disk check process run.
Pay attention towards the end you'll get a two second flash telling you if there were any problems, etc.
Let me know what happens.
Mar 02, 2009 | Microsoft Windows XP Professional for PC
Computer won't boot
when u power up the omputer press F8 key then go to safe mode.
then type in run "chkdsk /r"
then press "y"
then restart then it fixes error on hdd.
Jan 05, 2009 | Gateway M350 Notebook
Microsoft Windows XP Professional Logo
327 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
