Question about RCA HD52W59 HDTV Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
Screen is 3d, colors are out of wack, screeen is bowed, and auto convergence is not in the menu. most likly fl231 fuse is blown. my question is has anyone fixed the problem by just replaceing the fuse or is it more likely another problem causing the fuse to blow? has anyone experiencing this have a solution? it seems that there are about 4-5 possibilities but no solutions.
  • 3 more comments
  • rdevlin310 Jan 02, 2009
    I have the same exact problem. Wanted to know it replacing the one fuse will work or is this something bigger. And does any 125V fuse work or do I have to get specifically a FL231 fuse? Having trouble finding them.
  • burzum10 Jan 02, 2009
    i will give that a try i have resoldered all the flyback connections and pulled the fl231 fuse wich is blown i will have to wait for the fuse to come in as no one seems to have one in stock and i will post the results.
    thanks for your help
    douglass
  • burzum10 Jan 10, 2009
    ok replaced fuse and resoldered flyback connections and now there is no picture and the little green power button flashes 2 or 3 times and there is a sound inside the tv every time it flashes.
    douglass
    i for got to plug in a wire to the board plugged that in and now tv works fine thanks for your help
  • Anonymous Jan 17, 2009
    how do I get the fl231 fuse out? do you just pull on it?
    Genius:
  • 1,030 Answers
I have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Posted on Jan 02, 2009
I have Rca 52 inch that when I turned it on it was bowed at the top and the bottom, the images are double and the color is off.
sems like to me you have a convergences problem chedk conveg board and convergence chips and risistor or try replacing it. or try auto convergence. useally when when they are bowed at the top and bottom its the conver board..i hope this will help
May 28, 2012 | RCA Televison & Video
Screeen is bowed and i have a ghost or 3d effect on the screen. the tubes may need to be converged, but not sure how.
This RCA DLP tv model have auto convergence at it menu,lost it from the menu or can't get to converge,this tv have a convergence fuse mean the convergence fuse FL(231) near the FBT-flyback tranformer is dead.U have a soldering iron,a roll of desodering braid or a desoldering pump and a roll of solders,also can do basic soldering.Try website like Ebay.com to buy a convergence fuse(FL231) to do the replacement.
Feb 07, 2011 | RCA HD52W59 HDTV Projection Television
Turns on with sound but the picture is running colors mostly see red and blue also double vision. 3 colored lines show up on screeen when first turn on
do you have the convergence option in the customer setup menu? is the picture convcave bowed in at top and bottom. if you dont have the convergence option you might have the fl231 fuse problem. or something simular. first read this to determine if you do. if you dont you might have still have a convegence issue http://www.fixya.com/support/r1062030-fl231_problem_convergence_not_in let me know i am here to help.
Nov 07, 2010 | RCA HD52W66 Projection Television
Tv screen looks bowed out and the color is out of wack
Convegence Power supply problems are common for most GE/RCA projection Sets. Post more info - model # chassis # age - Did you try adjusting convergence?
Oct 24, 2009 | GE Televison & Video
I have rca 56wh78 56" with a bowed screen
You need to replace the FL231, DL231 and CP230 You can get the parts and instructions at the following link cost about 12.00 total. The parts are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
May 30, 2009 | RCA P52937 52" Rear Projection Television
step by step instructions are avalable in the tips and tricks section of this website.
May 29, 2009 | RCA HD52W59 HDTV Projection Television
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 12.00 shipping is free. the parts are all listed under the RCA parts category.
May 28, 2009 | RCA HD52W59 HDTV Projection Television
Colors out of porportion, maybe a bulb went out
When you have a 3-d effect. this is called convergence. Is the picture disorted or bowed in. if the picture is bowed in then this is an indicaTION of complete loss of power to covergence curcit. I always check to see if you have the convergence option in the setup menu if you do not then i suggest reading the fl231 problem in the tips and tricks sectionl
Mar 15, 2009 | RCA HD52W58 52" TV
RCA D52W20 52" TV AUTO CONVERGENCE WON'T COMPLETE
Sounds like your convergence chip has gone bad. Usually costs about $300-$400 to fix. I would call a local TV repair shop and let them give you a free estimate.
Jan 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 HDTV Projection Television Logo
186 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
