Question about Toshiba Satellite M45-S165 Notebook
Problems with MATSHITA DVD-RAM UJ-840S for Toshiba Satellite M45-
I own a Toshiba Satellite M45-S165 and my current driver is a "MATSHITA DVD-RAM UJ-840S". No CDs are read when inserted into the computer. I went to device manager and there is an error with "Windows cannot load the device driver for this hardware".
  • tkearley Apr 25, 2009
    I have the same problem, plus when I want to burn to the CD, I receive an error that "disc is not found" when a disc is in the burner.
Busco matshita dvd-ram uj-840s driver para el windows xp. Alguien me puede ayudar? No lo encuentro en ninguna pagina. En la pagina oficial solamente existe para el windows 2000. Gracias.
Not sure of your question; I read only English.
There are many sources for the drivers for your DVD; many would liek you to downlaod and use their driver update programs. An advantage is if there is ever an additional update the program will let you know. Here are two examples that you might consider as sources for an updated driver:
http://driver-helper.org/matshita-drivers/matshita5/matshita-dvd-ram-uj-840s-ata-device-driver-download/
http://www.driverboost.com/lp/drivers/update/Matshita-System-Drivers.php
Dec 28, 2010 | HP Computers & Internet
My Toshiba Satellite M45 bit it, and I had to
Sorry didn't see you already have it. Well go to that site, and enter the model number, it will come up with the driver you need.
May 15, 2010 | Toshiba Satellite M45-S331 Notebook
Need driver for matshita dvd ram uj-841s
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
May 13, 2009 | Toshiba Sattelite A105-S2051 Notebook
Dvd driver for toshiba m45-s265 corrupted or missing
Try to install free PC fixer from download.cnet.com then scan your laptop, I have the same problem with my Toshiba M-45 few months ago and now DVD drive is working fine.
Feb 27, 2009 | Toshiba Satellite M45-S265 Notebook
Matshita dvd-ram uj-831s driver missing
please go in bios check the drive is shown there.
if shown and not showing in my computer then might be the os issue.
Go to the device manager and check any yellow question mark on the dvd/cd rom drive and if not then try following
Right click and uninstall the drive.
Go to IDE ATAPI controllers in device manager and uninstall secondary controllers or ata channel 1 from there.
Go to run option>type regedit and enter then>H_KEY_LOCAL_MACHINE>SYSTEM>CURRENT CONTROL SET>CONTROL>CLASS>first entry starting with the 4D36 and single click on entry>on the right hand pane check for any lower or upper filter and if there delete both.
Restart the system twice then check if then also not working might be OS or drive faulty
Thanks.
Feb 22, 2009 | Toshiba Satellite A205-S4617 Notebook
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
Matshita DVD-RAM UJ-840S problems
if the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
Apr 26, 2008 | Toshiba Satellite M45-S165 Notebook
Dvd ram region locked.
Once your drive is locked im not sure you can do anything. I found this site which may work but i havent tried it.
http://www.gromkov.com/faq/faq2004-0063.html
Worst case replace the DVD drive.
Jan 12, 2008 | Toshiba Satellite M45-S165 Notebook
Toshiba Satellite M45-S165 Notebook Logo
483 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
