Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
I cannot find the WAN connection..Where should the blue cord connect...I just placed it in the WAN jack on the hub..
    Genius:
  • 1,689 Answers
If you want a WAN you need a router, and not a HUB.
If you have a switch, and you want to work with fixed IP addresses, you can do this but it will get involved with using gateways and etc.
The easiest way is to get a router, and set everything up with DHCP.
Jerry G.
Posted on Jan 02, 2009
I moved. magic jack says no line when hooked back up
  • Is everything turned on?
  • Is the blue light, inside your Magic Jack dongle, on? (Note that the Magic Jack Plus should have a flashing red and green led as well.) If you use the older model you might need to connect it through a powered hub to ensure the device receives enough power to operate properly?
  • If this is a new installation, is your internet service and computer capable of handling the requirements placed upon them by Magic Jack?
  • Do all your connecting cables appear to be firmly attached?
  • Are you watching Netflix, downloading or streaming files at the same time you are attempting to place a call?
  • If you are using the Magic Jack Plus, does the system report Error 3002?
Next, you should ask yourself what recent changes you have made to the computer/Magic Jack software? What recent upgrades have you performed to your hardware? Could this have effected the performance of your Magic Jack?
If your difficulties persist, it is time to divide and conquer. Google a 'you tube' link and watch the video. If you cannot connect to the internet, consult your internet provider for assistance. If the video is choppy, the internet connection might be too slow or bogged down. Perhaps your computer is too slow or requires maintenance. If you cannot hear sound, you might be experiencing problems with your soundcard or sound drivers. You should check Control Panel/Sound and ensure that 'USB internet phone by Tigerjet' is installed.
If the video ran correctly, the next step would be to test your handset and phone cord at another location.
If you prove the handset/phone cord to be correct, you have pinpointed your fault to either the Magic Jack or its software. Contact online support for Magic Jack.
Oct 11, 2014 | magicJack Plus Pc To Phone Adapter
HP Pavillion dv6700 - won't power up
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Feb 16, 2013 | HP Pavilion Computers & Internet
Power supple must be pushed to the left, while inserted in connector, to power on dell latitude d520
Either one of 2 things has happened: (1) There is a part of the DC Jack there that has become bent out of place and by moving the cord as you describe it is connecting properly. or (2) The DC Jack solder connections on the motherboard have come loose and need resoldered. If you find it is #2 I suggest replacing the jack as opposed to just re-soldering to guarantee it works for time to come.
Dec 16, 2012 | Dell Genuine Ac Adapter 90w Latitude D 630...
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
BACK PANEL OF CAR MP3 PLAYER UNDERSTANDING CONNECTIONS. i'VE JUST BOUGHT A CHINA MADE CAR MP3 / FM PLAYER. IT'S BACK SIDE HAS GOT 2 SETS OF SPEAKERS CORDS. ONE BLACK CORD LOOKING LIKE AV CONNECTION JACK...
from what you describe, the red wire is definately power in to the unit ((+) hence the fuseable linkage). Blue is an odd color in electronics, so if its next to the red it is more than likely return voltage ((-) in DC circuits return voltage is grounded. Typically a head unit will have the wire diagram printed on a sticker placed on top or the back of the unit.
AND FOR THE BLACK CORD, thats for then fm antenna, there should be a cord that looks just like that one behind the unit, only the vehicle end is the male end.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 05, 2010 | Car Audio & Video
What does ''WAN'' stand for above one of the ports on the back of the router?
WAN stands for Wide Area Network. It is the port in which you plug in the cable from the data port on a modem.
Apr 05, 2010 | Computers & Internet
Don't know how to hook up my router kids unpluged.
This is an easy fix. The back of the router has a single power jack and 5 jacks for network cables. 4 of the jacks are grouped together on one metal "plate" and are called LAN or "Local Area Network" jacks. The 5th jack is removed from the others slightly, and is by itself on its own metal "plate" closest to the antenna. This jack is called the WAN or "Wide Area Network" jack.
Disconnect the power cord if not already unplugged.
The WAN jack (closest to the antenna) should be connected to your DSL or cable modem output with a cable long enough to stretch between the two.
The LAN jacks should be connected to the computer(s) network jacks in your home that do not use a wireless connection.
Once everything is connected, turn on the DSL or cable modem (if not on already). After 30 seconds, power up the WGR614. After 30 seconds, you should see the power light on, the test light (a check mark) should be off, the wireless light (the antenna) may be on or off (depending if you configured it to be on before) and the internet light should be on or blinking (it's the icon next to the "1" light). If the internet light is off, check the WAN jack and cable back to the modem and make sure the modem is on.
After the internet light is on, turn on the wired computer(s). The 1, 2, 3, and 4 lights will flicker when computer(s) are on and connected to the 1, 2, 3 or 4 jack(s).
I hope this was helpful!
Oct 26, 2009 | NetGear WGR614 Wireless Router
DES-1008D connectivity issues.
Is the modem a DSL or cable model?
Does the router have one ethernet port and a WAN port?
Normally the broadband modem is connected to the WAN port on the router and the ethernet port on the router is then connected to the hub/switch and the computers are then connected to the hub/switch.
The modem gets an unique IP address from your Internet Service Provider and then the router then issues Class "C" IP addresses to each computer that is connected to the switch/hub.
Jul 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Lan
Hi - you connect the ethernet port on your modem to the wan port on your hub. You can then hook up your other devices to your hub. If this solves your problem PLEASE rate this as fixed. If it didnt, DO NOT RATE yet. Just add a comment letting me know you need more help and I'll be happy to assist you furter. Thanks and have a nice day. Remember if you need more help just add a comment.
May 10, 2008 | Compex MicroHub TP1008C Networking Hub
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
148 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
