Question about Insignia 37" LCD Flat-Panel HDTV
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  Currently I have the cable box connected to the TV with HDMI cable, and the DVD player/recorder hooked up separately directly to the TV with coaxial cables.
  • 20 Answers
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Posted on Jan 10, 2009
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
My husband bought me your DVD Recorder Model No. DMR-EH75V for Christmas in 2006. It worked with my analog TV and a COMCAST cable box. In April 2007, I bought an Olevia HD TV and changed to a Verizon...
Due to certain limitations of the Panasonic DMR-EH75V, it can only accommodate composite Video INput and give composite Video OUTput as well as the standard Audio L/R. Additionally, if your Verizon FIOS HD cable box has an RF OUT, that can also be connected to the RF/CABLE IN of the Panasonic.
Please refer to the simplified diagram below.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Televison & Video
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Sold as HD Ready, but hopw do I connect HDMI to it to get HD picture ?
to hook hdmi to it you need to purchase a hdmi cable and plug it into the tv and then into what ever you want for example like your cable box,dvd player,etc.once hooked up turn tv to hdmi input
May 31, 2009 | Panasonic Televison & Video
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Recording TV
Hi.. it looks as if that particular dvd/vcr is not compatible with the coding digital signals that the hdmi is putting out so it's not converting the signal over correctly.. if you try just using the regular analog cable instead of the hdmi, that might solve your problem.. i hope this helps..d
Jan 24, 2008 | Samsung DVD-VR357
Will not play HD DVDs. & will not record
First off this is not an HD dvd player it is a dvd player that has HD upconversion. secondly if you want to record a cable show you will need to push that into the dvd recorder with the a/v input.
Dec 29, 2007 | Samsung DVD-R135
Insignia 37" LCD Flat-Panel HDTV Logo
400 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
