Question about Dual XD7600 CD Player
Face Opens and Closes and opens and closes...etc..
One summer day my faceplate got stuck in a mid-open position. I unplugged the power supply and hit the reset button and it closed. Since then (months ago) when I hit the OPEN button, the faceplate opens and closes over and over again.. I've disconnected power, cleaned connections I see but no change. I've also lost all of my personalized settings i.e. volume level at power up, default positions, etc.. and I lost my manual so I can't reset those. I kept the player b/c of it's handy aux input, but now my ipod has died as well,and I can't rely on the stereo for music or radio! I think the heat in my area (Mid-East Alabama) may not be good for it, but come on, it's a car stereo, it's gonna get hot, right? I hope someone can help, otherwise I'm off to the stereo sites.. Thank you! -W
  • 6 Answers
SOURCE: Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Posted on Aug 28, 2007
  • 132 Answers
SOURCE: Freak Out!!!
Correct on the ribbon cable but parts can be ordered for it, duel has service centers, inc the one i work @. its abought a $10 part
Posted on Jan 03, 2008
  • 132 Answers
SOURCE: Opens and closes
there is a ribbon cable thet goes out from use that causes it. Contact duel for a rep part or a service center near you
SOURCE: drop down face problem
try resetting it by pressing the little button on the front of the face
Posted on Feb 28, 2008
SOURCE: Volume only goes up with faceplate open
Tienes un problema con los push buttons en la carita uno de ellos esta danado.Resetea tu estereo en la carita tiene un mini orificio con un boton para resetearlo intenta esto,suerte.
Posted on Apr 09, 2008
SOURCE: Flip Down faceplate is stuck.
I have the same problem, and all my problem was is that one of the wheels were out of place. You can see these white gears at the bottom left and right. Just stick something in there and push it back in place. It should just snap back in.
Posted on Aug 26, 2008
0 characters
1 Points
Faceplate won't open all the way
Sometimes the mechanism is misplaced, just disassemble that mechanism and turn on radio without the secondary plate and wait until the motor to get to the final position when it turns off again, reassemble.
Oct 06, 2012 | Pioneer Premier DEH-P960MP CD Player
Pioneer premier deh-p880 prs faceplate opens when you turn car off
The face folds down to give you the option to remove the face if you want. It will return to the upright position a few seconds later whether you remove the face or not. There should be a tab on the underside of the face you can push should you decide to detach the face from the chassis.
May 07, 2012 | Pioneer Premier DEH-P880PRS
Basically I have the same problem that has been displayed a lot on this site. My pioneer DEH-P7800MP display won't show when the face closes. When the face opens up all the buttons and lights and display...
The faceplate and head unit is is attached via a flat ribbon cable. (Caution only continue if you have some courage). If you open the faceplate you will see that the ribbon cable is seated in too a flat connector on the PCB (Printed Circuit Board). This connector has a locking mechanism on it that when locked presses the contacts of the cable to the connector. Ensure that the cable is seated properly and that the latch or the lock is in the locked position. Assuming that the tension lessons when the unit is closed so it draws away from the connector and when the unit is open it pulls tension creating a contact. If you see no signs of mishap on this end of the connector try the other end.
Hope this helps.
Nov 17, 2010 | Pioneer DEH-P7800MP
Kenwood KRC-x858 stuck halfway between closed and open
have the exact same problem. I called the Kenwood tech line and the tech reported that the ribbon cable2_bing.gif is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Jul 23, 2009 | Kenwood KRC-X858 Cassette Player
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Wont stay open
I had load of these units and the cure is simple. You need to replace the ribbon to the faceplate as these get damaged due to wear and tear. Every unit i had with this fault, i fixed by replacing this ribbon. Buy the ribbon and surround as the new surround is a modified one to give extra life to the ribbon. Hope this helps, good luck!
May 25, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer powers off when face plate opens.
My first guess would be that the ribbon cable between the flip face and the mother board has gone bad. This is a very, very common problem. I'd suspect that above everything else at this point.
Jan 03, 2008 | Car Audio Receivers
Mar 16, 2007 | Dual XD-7500 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Dual XD7600 CD Player Logo
Top Dual Car Audio Receivers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Pablo Gonzalez
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio Receiver Expert? Answer questions, earn points and help others
