Question about Brother MFC-7820N Laser Printer
Printed pages look dirty
When I print or copy anything on this printer, the copies look dirty, with all sorts of black smudges on them. The smudges roughly look like vertical lines, but not solid vertical lines, lines of spots. Is it a matter of cleaning the toner cartridge? If so, I need some instruction on how to do that safely because I don't want to break anything. When I took the toner cartridge out and shook it back and forth (as I was instructed to do by Brother technical support), some black dust fell out. Not sure what that was about. Appreciate any and all suggestions. Thank you!
  • Anonymous Mar 15, 2014
    After I changed drum and toner cartridge, there's still a black vertical line on page?
    Novelist:
    Scholar:
  • 104 Answers
That black dust that fell out is the toner. When you shake a toner cartridge that shouldn't happen. It looks like you have a faulty toner cartidge and that need to be replaced! Now to make your printer prints cleanly and clearly after you replace the cartridge, you'll need to get someone to service the printer(the faulty toner cartridge more than likely spilled toner on your internal printer parts, cause the smudges). Sevicing would mainly entail, taking down the printer and removing any spilt toner! If you feel you are up to this, be cautious, because toner can be hazardous to your health if you accidentally breathe it in! hope this was helpful! regards babb
Posted on May 10, 2007
Copies come out blank
you need to clean it more.and try to re-install the driver
Nov 20, 2013 | Office Equipment & Supplies
Printer smudging
sounds like the rollers are contaminated/ and or the print heads have stuck on them. you can use alcohol on a cotton swab to clean them.
Oct 13, 2013 | Kodak Office Equipment & Supplies
I have a Canon Imagerunner 1023if and have black smudges along the left edge of paper, both copies and printed directly from computer.
this is possibly a problem in the fuseing part of your machine, where the paper heats up at the back, the fuser roller could be worn out. and your toner could be sticking to it.
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
When i print out a paper, there is a black line through the print out.
I am assuming your black line is printed (not smudged ink)...
If your printer is also scanner/copier, try copying a page (rather than printing from computer).
If it scans & prints ok, it could be communication/driver problem. Try reloading the drivers and see if it improves. If the black line is there when copying as well, there's probably not much you can do about it.
hope this helps
LC
www.inkbank.com.au
Nov 10, 2010 | Brother Office Equipment & Supplies
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Can I fix this stuff without a service call?
black spots can also be caused by drum...
developer normally will cause blur print due to developer uneven or dirty (dust)...
Apr 17, 2009 | Office Equipment & Supplies
HP 3050 vertical black lines during fax
OK, from the desciption i can assume several things here are some option.
If by receipt you are talking about the confirmation the unit prints the the problem is likely dirty glass.
You would also get the lines when you make a copy using the ADF.
Open the lid there are two areas of glass the thin strip is likely dirty and needs to be cleaned.
If by receipt you mean pages you receive from someone else, and not printed or copied on your machine, then their machine has the condition described above.
If everything has the lines then you have a toner or fuser problem:
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Mar 24, 2009 | HP LaserJet 3050 All-In-One Printer
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Sep 16, 2008 | HP DesignJet 450c InkJet Printer
Black smudge streaks on rightside of printed/copied material
Can only be two things the drum or the fuser. More than likely drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine.
Dec 17, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
1,320 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
