Question about Samsung ML 1510 Laser Printer
Paper tray feed problem
For no apparent reason and with no apparent damage, the paper tray on my Samsung ML-1510 printer now pops out whenever I try to print a page, thus causing a print failure.
The only situation in which it appears able to print a page is when there are no more than around 5 sheets in the tray. The printing process then seems to be fine, i.e. there are no paper jams within the drum.
It seems that, for no apparent reason, significantly more force is being applied to picking up a sheet of paper from the paper tray. However, nothing seems amiss when looking at the central feed roller (elliptical shape) or tray (e.g. no cracks, broken plastic or dysfunctional spring).
Help, please!
  • 104 Answers
The shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Posted on Jan 06, 2009
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
Wheres the manual paper feed on a samsung ml-3051n
The Upper Tray (Tray-1) is the Manual Paper Feed Tray.
CreativeTECH
Jan 05, 2011 | Samsung ML-3051N Laser Printer
Samsung ML2010 Printer does not receive the Paper
Make sure you have put enough paper in paper tray. Printer will not pull paper if not enough. (more than 10 sheets) hope it works. : )
Aug 10, 2009 | Samsung ML 2010 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung ML-2250 red light
Check the paper tray. There's a latch along the lower left edge that's supposed to let the paper pop up when the tray is inserted so it can feed. If the tray looks OK, check the paper path again and look for a torn off piece of something in there. All it takes is one little piece of paper jammed in there to make the light come on. Use a flashlight and try blowing some air through it with the tray out, back door open and cartridge removed.
Mar 09, 2009 | Samsung ML2250 Laser Printer
Printer does not feed paper
Dear sir; That's very difficult to tell you detail how to take apart the parts, but I can teach you a easy way and tricky way, this cause you problem is paper pick-up roller, right above the paper tray. therefor you have move out the tray , remove the toner ctg. flip machine over (bottom up) then you will see the roller very clear, clean up with rubber rejuvenator, try it out, and please let me know how does it work, good luck! HAVE A HAPPY HOLIDAY !!!
Dec 18, 2008 | Samsung ML-2510 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Paper won't feed
You could try cleaning the rubber feed roller with a slightly damp rag, or even having feed assy replaced but you are right probally better off replacing it.
Dec 25, 2007 | Samsung ML 1430 Laser Printer
Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Aug 23, 2007 | Samsung ML 1651N Laser Printer
Samsung ML 1510 Laser Printer Logo
281 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
