Question about Amana AOCS3040 Electric Single Oven
Need to find trim
Need #31748603SS (77001230) this is NLA. new or used need help thanks
  • 87 Answers
Sometimes a web site will be able to get it,even though some sites list it as no longer available. Check www.partselect.com www.apwagner.com or www3.sears.com
Posted on Jun 08, 2007
Kenmore beeping, oven starts and shuts off, new touch pad
This is usually a control board failure. It may be NLA (no-longer-availble) from the OEM, but we can rebuild it for you. Also, this article may help you:
Oven Failure After Self Clean and F1 Errors
Sep 16, 2015 | Kenmore Ovens
I have a maytag wall oven it shows error code f2eo what does this mean and how do I fix it?
E0 F2 is usually a stuck key on the keypad. You will need to replace your keypad most likely. It's possible to be caused by the control board also. If it is NLA we can rebuild it for you at fixyourboard.com
Aug 13, 2015 | Maytag Ovens
Whirlpool rb270pxyb
no such thing. when it is NLA it is NLA.
Apr 18, 2014 | Kenmore Ovens
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
Nov 09, 2013 | Thermador SC302T Electric Double Oven
Having trouble removing my oven from the wall in order to replace the bottom heating element.
What model?    Is it a 'wall-oven'?  If so, many have trim pieces on the sides that cover actual mounting screws.  Also- these units are extremely heavy and require two people to remove/install. Trim pieces are usually held in by screws accessed with door open. Some trim slides up to release. With trim off mounting screws should be visible. Remove these, and unit should be free.Wiring behind unit can also be shorter than most people think, so have something to set it on.  Please acknowledge this posted solution if helpful-  Have more info if needed- Thanks-- Ed
Mar 24, 2010 | GE Ovens
Reassemble door glass
this should help.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RF375PXEW0&productCategoryId=0124111&brandId=1198&modelName=ELECTRIC-RANGE&diagramPageId=00005&componentDescription=DOOR&documentId=O2024784&backToLink=Return%20to%20Sub%20Components%20list
you can take a screw form the back panel on the back of the range and use that. let me know if you have any more questions or if you need clarification
Jan 03, 2009 | Ovens
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Amana AOCS3040 Electric Single Oven Logo
50 people viewed this question
Top Amana Ovens Experts
Oloyede Monsuru
Joseph Hoffmann
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
