Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Freezer froze up, refrigerator compartment warm after hooking up
We bought a used Whirlpool ED25QF side-by-side Christmas Eve. Worked fine for a few days till the weekend when we finally got the water hooked up. After that, freezer has stopped blowing ANY cold air into the refrigerator part, and all the food is not cold enough. None of the vents, airways are blocked, all the seals on doors are tight, water isnt leaking in the back...we dont know what the problem is. Any ideas anyone??
  • tdc1 Jan 20, 2009
    i have the same problem. After the relay to the compressor went bad, I changed the relay. The freezer is getting cold but the refrigerator isn't.
  • 115 Answers
Look in the freezer and see if there is frost on the back wall if so take back panel off and checked defrost t-stat on top of the coil leave it in the ice and cut the wires and ohm it out if there is no ohms it is bad if it is good check the heater
Posted on Jan 03, 2009
Freezer and refrigerator are not keeping cold
the thermostat controler is most likley bad this is where you set the temp with the knobs you can find the parts online with the model number please rate- jeff
Sep 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Why did my refrigerator quit working but the freezer side still works?
Your freezer is probably froze up with ice. Pull all your food out of it and shut off the refrigerator. this will let the coils warm up and melt the ice.on the freezer coils. There are coils behind the freezer that freeze up up. I ran a hair dryer in there freezer on low for a few hours to speed up the process.
Aug 06, 2014 | Whirlpool Refrigerators
Freezer frozen on bottom and frige cold on bottom only. No airflow coming from vents inside freezer or top left of frige, freezer and frig warm at the top. Model is a ED25QF
check to see if fan is running in freezer if it is you may have a defrost problem if not replace the fan its the evaorator fan that is in the freezer
Mar 08, 2010 | Whirlpool ED5FTGX Side by Side...
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
My Whirlpool side by side keeps freezing on the regular side.
your damper door is most likely frozen in the fully open position,thaw it out if iced up,then adjust cold control to see if it closes,the door is inside between the refrige and freezer compartments,also if this happens again check the door seals to make sure they are sealing good and not letting in warm air that can condense and refreeze this door
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirlpool Refrigerator Model ER8MHMXML02 isn't as cold. Help!
Freezer drain plugged and froze up also froze the air returns to frig
Aug 22, 2009 | Whirlpool Refrigerators
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Whirlpool Ref shuts down
It sounds like to me its your defrost timer(usually under 20.00) that is bad. Yhe are very inexspensive and easy to get to.You can purchase one AT YOUR LOCAL SEARS or online with your model # Glad to be of service
Jan 08, 2009 | Whirlpool Refrigerators
Whirlpool gold gd25df Fridge/freezer warm
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Aug 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
144 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
