Question about CyberLink SW- DVD Software Power DVD (SWPOWERDVD) DVD Drive
Computer Freezes While watching a DVD my computer freezes up and I have to take the DVD out and reboot. Sometimes rebooting works but other times it doesn't.
  • 45 Answers
Hi djd;
sometimes the DVD ROM is no able to read the DVD properly due to many reasons.
just copy the dvd to ur hard drive and play it from there.
this will fix it.
Posted on Jan 02, 2009
Hp pavilion dv6 freezes
You may have to reformat the drive and install the operating system again. Back up all data you want to save and put it on a DVD or flash Drive first. Do a Clean installation to avoid a carryover of damaged files, code, and any malware.
Dec 24, 2013 | HP Pavilion dv6-6c00 DV6-6C40US A6Y50UA...
Optiplex 330, fails to POST and locks
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer.
Aug 28, 2012 | Dell Optiplex 330 Desktop Computer Pentium...
My Compaq (615 AMD Athlon X2 64). My touch pad started freezing about some 3 months ago. I can still work with the keyboard when the touch pad freezes. I tried uninstall the synaptic software and...
Hi Silasissifu,
It coule be problem with the drivers too... Make sure you update the drivers and check again. it should fix the issue for you.
Go to manufactures site or to google and type in the make and model of the computer and search for touchpad drivers and install them.
Thank you
gowtam1402@live.com
091-9916828137
Jan 05, 2011 | Computers & Internet
From time to time the TV picture freezes, and I have to reboot before I can continue watching programmes
Pull the power cord out of the back of the box and plug it back in again. Your box is probably locked up. A cable tuner or a satellite tuner is nothing more than a pretty primitive computer, and like any computer, it sometimes freezes. That's generally what's going on with that particular system.
Normally when a picture freezes it isn't the TV but the signal the TV is receiving from whatever source it's hooked up to. If you have digital cable and the company is having any type of technical difficulties with their signal, it can cause the picture to freeze. If you've ever watched TV with someone who has Dish or DirecTV while a storm was over-head, you may have seen it happen to their picture. However, if you're able to rule out the cable equipment and the cable company as being the problem, then there is something wrong with your TV. So whatever the case, if it's the TV the only troubleshooting you can try is to unplug the unit for 30 minutes. If that doesn't fix the issue, the TV likely needs to be serviced.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Televison & Video
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
Feb 07, 2010 | Apple 24" iMac Desktop
System freezes when mouse put on charging module
If this charging module came with software that you have installed on your computer, than try uninstalling that software and rebooting your computer. Next reinstall the software and reboot again. The installation may have been corrupted. If this does not solve the problem than see if there is software similar to this that is causing conflict with your module.
Mar 13, 2009 | Verbatim WRLS RECHARGEABLE DESKTOP LASER...
Computer freezes
If you save your important information and have all you cd disc to reinstall a fresh o/s. This can change what is happening to you.Some times I just will reinstall it a few times over again just to make me feel better.It seem to run extra fine after that.... thesuperboss
Dec 28, 2008 | Microsoft Windows XP Home Edition
Acer Monitor AL1706 freezes w/ horizontal lines after burning cd
The issue is you system, download memtest86 and run it from disk if you get any error your ram is bad or it my be the program you are using try uninstalling it and reinstalling it
Dec 09, 2008 | Acer AL1706AB LCD Monitor
HELP
I would check the Ram and CPU. If you can swap the ram you have with good ram, or if you have more than one stick of ram in there take one out at a time to see if thats the problem. Next go into bios and check the CPU temperature after you have been running your computer for a while. The problem with diagnosing this problem is how much time in between freezes. 18 times in 6 months makes it hard to diagnose, because you won't know if you fixed the problem unless it freezes again after you changed something, and even if it does freeze again it could be because of an entirely different problem.
Aug 23, 2007 | Toshiba Equium 7100S PC Desktop
Computers & Internet Logo
69 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
