I need your help or i wil have to return it i used it all winter don't drink in the summer months just went to clean it today and heating light dosen't light up and nothing comes out.
SOURCE: COFFEE MAKER IS MAKING LOUD NOISE AND WON'T BREW COFFEE.
Do you have hard water or othe deposits in the water.? It may have just limed up. Try soaking it for a couple of days with Vinigar and water . put a healthy amount right in there add sum H20 and waite. this may free it up Good luck. DSFD
SOURCE: coffee maker not brewing
9 times out of ten , the needles on the the k-cups are plugged so water is not allowed to pass. clean with toothpick , small nail, etc.
SOURCE: My Keurig Elite B40 will only brew one cup of
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: Keurig coffee maker is saying
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: All of a sudden my
Mine started to do that about a month ago. I would have to brew multiple "cups" just to fill one coffee cup. I ran several cycles of the largest cup, without any K-cups, to clean out the small metal spout. After about 3 hot-water cycles, it worked fine. I do this periodically, as I don't use the Keurig daily, so some of the residue builds up between uses.
