Question about Seiko Melodies in Motion Clock
Clock grinds when face moves
I have the beatles fanfare clock - Item# SKO002. The one that the face of the clock opens (spreads aprart). It grinds trerriblty noew when it opens and closes. What can be done?
Scott
3 Suggested Answers
SOURCE: The glass front of my beatles clock broke.
you just go to a clock store and look for the same thing and just buy it.
Posted on Mar 08, 2010
gemineye61
  • 831 Answers
SOURCE: my seiko motion clock face opens and does not
Thank you for contacting FixYa
I am not as experienced in the clock side of Seiko, but I did find their website and it is filled with great recommendations for clock repair. I would highly recommend you contact Seiko on this.
Best regards. Here is a link to go to:
http://www.seikoclocks.com/#FAQ
Thanks for your rating too!! Jewel
Posted on Sep 02, 2010
How do I get the chimes to work on a howard miller grandfather clock they worked fine till I rewound the weights and stopped
There are a number of things that can cause this. The most obvious is to ensure the weights have been wound up (either by pulling the chain or using the key that comes with the clock). Next is to ensure the clock isn't on "silent" mode. Some clocks, especially the more expensive models, have a small pull rod just behind the clock face. You can usually find it by opening the front door, and looking just under the wood frame the surrounds the clock face. Pull or push to enable/disable silent mode. The next option is to look at the clock face/dial itself, check to ensure it's not on silent. Sometimes there is a lever on the right or left of the clock face. Next, some "triple chime" clocks have either a turn dial or lever on the left or right of the clock face. This lever usually has four options Westminster, St. Michael's, whittington and silent. Check to ensure it's not on silent. If it's on for example Westminister, try moving it to St. Michaels. If the clock then starts to chime, you know there is an issue with the movement that needs repaired. You can also open the clock, if you feel comfortable and check the lifting levers aren't stuck, I've found this a few times. Additionally, while it's a bit hard to explain, on some movements there is a long rod that pulls almost all of the rods back at the same to make the "bonging" sound when the hour chime arrives. This sometimes ends up misplaced on the wrong side of the chime hammers. As you can see there are a number of things that can cause a clock to stop chiming, but a little research on your model and some confidence and you can usually fix most problems fairly easily. The only exception is if the movement has been neglected over the years (failure to oil etc), in which case a rebuild may be required.?
Dec 02, 2017 | Home
Unable to set clock on pioneer super tuner IIID - tried holding down clock button but time doesn't flash. Your assistance will be appreciated thank you
To set up the clock...
Turn radio off.
Hide clock face.
Press and hold a few seconds “clock button” to bring clock face up.
Press and hold “power on button” till clock starts to blink.
The 4 buttons in a cluster on the right under audio, move the hours and minutes.
press power when done.
I hope this helps
Please rate accordingly
Thank you
Computerrep
Apr 27, 2008 | Car Audio & Video
How do you reset clock on fitbit blaze?
Blaze offers several designs for the clock. To see your options, open the Fitbit app and tap or click the Account icon () > Blaze > Clock Face. If you change the clock face, sync your tracker to see the change. Note that if you see an error screen after changing the clock, you should restart your tracker and try updating the clock again. For instructions
Apr 07, 2017 | Exercise & Fitness
When my melodies in motion clock plays the music (Beatles), it sounds distorted.
You may have a loose speaker wire connection or the speaker could be bad.
Dec 09, 2013 | Seiko Melodies in Motion Clock
Elements work but both ovens and clock face are off
Reset breaker or unplug and restart stove. Open back of stove to clock face and make sure the harnesses are tightly fitted to clock board. You could even remove and reinstall the harnesses to the clock board.
If able, check for 120v to clock. If clock is getting power but not lighting up, replace clock.
You did not say whether the clock controls the oven; ie. oven does not work when clock is off. if so, replace clock. If not, ignore it unless you want to know the time from that clock.
Oct 20, 2013 | Maytag GeminiĀ® MER6765BA Electric Kitchen...
How do you set the clock
These are generic instructions for a JVC car stereo:
1. 1. Hold "SEL" button
2. 2. Select CLOCK H or CLOCK M with the fast forward button or fast backward button.
3. 3. Adjust item with wheel
4. 4. Finish by clicking on "SEL" button
5.
Manual can be downloaded at:
http://support.jvc.com/consumer/product.jsp?categoryId=CATG0004&archive=true
May 05, 2011 | JVC AM FM CD DET FACE CAR STEREO
Mar 08, 2010 | Seiko Clocks Melodies In Motion QXM135BRH...
Trying to set clock on a Pioneer DEH-10MP
leaving ignition "on" and radio "off". Had to open face and press/hold "func" button. I was then able to scroll through multiple settings until clock appeared. Used right-hand big button to move between hours and minutes and set time.
Feb 01, 2009 | Pioneer DEH-P3500 CD Player
SETTING THE CLOCK
The analog clock has little buttons on the face to move the time forward or back. If your FX has NAVI hit the setting button then choose CLOCK. If it doesn't have NAVI hit the menu button and scroll down to the clock setting.
Oct 16, 2008 | 2007 Infiniti FX35
Jaguar 1995 XJ6
The clocks go bad unfortunately, they cannot be repaired.
To replace the clock it is a costly item, I have seen a few people buy a rectangular clock and velcro it to the face of the original clock.
Sorry it can't be repaired and last time I check the new clocks are around $250.00
Sep 27, 2008 | 1995 Jaguar XJ6
Seiko Melodies in Motion Clock Logo
Top Seiko Home Experts
Jimmy Accardi
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
