Question about JVC AV-48WP30 48" Rear Projection Television
Tv shut off and wont come back on
My tv shut down and when i turned it back on it made a clicking sound for 5 sec. and then it stopped. the blue power light now flashes and no tv picture or sound? thanks for any help u may give, jb
Hi I had the same problem with my TV and I fixed it by changing the 2 ic's part #STK392-110. Very common problem with this JVC TV. Its the 4th time i change them.Circuit runs to hot and burns them out
Posted on May 12, 2007
    Scholar:
  • 77 Answers
Your TV is going into some kind of a protection shutdown. In todays tvs just about anything wrong anywhere and the tv will do what it is doing. Unfortunatley there is probably little you can do yourself to track it down, probably need a pro.
Posted on May 10, 2007
How do I fix my power cycling tv??
I have found that the solder connections get loose where they connect to the p.c.b. please make sure its not plugged in and don't touch the hv probe going to the tube. It will be the last time. Be extremely careful and keep one hand behind your back. If that's not it, the power supply has gone south. Get another TV.
Sep 03, 2015 | JVC LT-46P300 46" 1080p LCD TV - 16:9 -...
Computer will not start
Press power button down for 5seconds until the computer shuts down. Remove power cable, press power button down 10s. Connect cable, try to restart.
Aug 17, 2012 | Dell Computers & Internet
At times pc wont turn off with mouse windows shuts down but computer will turn off and on again immed
Try draining the power of the computer first. completely shut it down by pressing poweer button for like 5-7 sec. then unplug power supply from the outlet. then press and hold power button for another 15-20 sec. After that, plug back in the power cord, and turn computer on normally.
Apr 03, 2010 | Compaq Presario 5000 PC Desktop
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
JVC 42 inch LCD HD TV has no picture or sound
utencilio posted this fix. It worked for my JVC LT-42X579.
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first
Jan 28, 2009 | JVC LT-42X579 42 in. LCD TV
Hi i need your help please
When you adjsuted for the blue you were actually adjusting the voltages to the CRTs (lamps) which in turn shut them down. You will need to turn each one of the dials up agin untill your tubes stay lit, then the coolant in the green and blue CRTs will need to be changed as the green evidently is contaminated thereby making the blue dominant. But when you turn down the G2 controls your actually turning down the High voltage to the picture tubes thats why they dropped out on you.
Aug 24, 2008 | Televison & Video
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
128 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
