Pioneer AVIC-D1 Car Video Player Logo
Posted on Jan 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ADIC-D1 auto muting
My system is muting by itself. It will come on for a while and then MUTE apperars on the screen. It will flash on and off for no reason.
Chris Sorrows
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 136 Answers
  • Posted on Aug 08, 2009
Chris Sorrows
Expert
Level 2:
Cheetah:
Answers
136
Questions
0
Helped
41412
Points
396
Check the "mute" wire. It's probably grounding out causing it to mute.
Vizio D55U-D1 has no picture
https://www.youtube.com/watch?v=f324xmqpsMs
https://www.youtube.com/watch?v=Bcz39rzy0o0
Press and hold the 'Mute' button on your remote for 5 seconds to ensure your screen isn't muted. Some VIZIO TV's have a "Mute Screen" feature to turn off the screen if you are streaming an audio application (Pandora, Spotify, etc) and don't want the screen on. https://support.vizio.com/s/article/No-Video-No-Picture-Black-Screen
3answers
JVC STERIO RECIEVER MODEL RX-554VBX
on remote try to un mute it is a ch only on not a and b or none use a ch only go in main menu of system cheak auto mute turn off
1helpful
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Why does it go to auto mute, and how do i turn it off?
You did not mention which operating system you are using and it is a bit different in each.
XP: click start > click control panel > click display > click screen saver tab > click the power button > adjust timers to never > click apply
Windows 7: click start > control panel > power option > change plan options >adjust to never > save changes
Windows 8: swipe down right side > search "power" > click on power and sleep > adjust to never
Turn off mute
Most likely it is your Flash player causing this. Try the steps out lined here:
https://forums.adobe.com/message/4041846#4041846
This will update your Flash Player with a clean install.
Yamaha ysp-800 stuck on mute, volume indicator just flashes
Did you ever get a solution to this? mine is doing the same. i press the mute button and it says audio mute off but no sound still and volume indicator keeps on flashing.
2answers
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
2helpful
Nad 712 output issues - Mute flashing
The only thing I can tell you for sure is that the mute indicator always flashes (very dimly) when the receiver is off.  I have no idea why, but mine has always done this.
Jan 23, 2007 • NAD 712
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
