AGGITATOR NOT MOVING FREELY - Washing Machines
  • 15,935 Answers
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Agitator is not moving
You have stripped out the Aggitator or the Bolt came loose. Pop the Top on the Aggitator. There is also a chance that there is SOAP build up inside that is causing a problem depending on the machine...
Apr 12, 2013 | Maytag Centennial MTW5800TW Top Load...
Washer fills with water but will not drain and the aggitator is not moving either. Could the problem be a bad or stuck aggitator?
When the machine is ready to drain get the hose in the back and put it down either out the window or in the tub what ever is closer and the water runs out on its own
Aug 06, 2011 | Washing Machines
My kenmore washing machine model # 11021882001 will fill up with water and drain like it should but does not aggitate at all but it sounds like the motor is spinning freely
Should be one of 2 problems
1 Try and turn the agitator back and forth it should only move in one direction if you can move it both ways then the agitator cam and dogs are worn/broken You can order the kit from HERE
to replace it See this diagram
2 if the agitator is ok then its the drive coupler on the motor You can order it from HERE
Here's how to replace it
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Washing Machines
Washer aggitates poorly when it is loaded
Check belt tension. Motor capacitors weak. Check the spin mode. Finally check the motor.
Apr 03, 2010 | Washing Machines
Model 110.26901690, aggitator spins freely both directions when moved by hand. Wash drum rests off center to the front of machine.
You've got a brake/transmission problem. This is a major fix, best left to a qualified repairman and probably means you're going to have to evaluate whether it's cost effective to fix vs replace.
In your cost evaluation, recognize that even after it's fixed you still have a unit with the value of a USED appliance.
Jan 01, 2010 | Kenmore Washing Machines
Kenmore 20842 won't spin or aggitate
Check your motor drive coupler. Tilt washer back against wall and look between motor and transmission . You will see a rubber grommet and two plastic couplers on each end of rubber , They may appear broken or you will see rubber shavings under washer.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not aggitate all other functions work fine
Sounds like you need a set of dogs...(dog agits)...
Pop the top off the agitator and remove the bolt. Pull the agitator top off and inspect the dogs...(small tear drop shaped pieces of nylon)...
Sounds like the dogs lost their bite aka teeth.
Apr 11, 2009 | Washing Machines
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Washine mashine aggitator
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
Dec 03, 2006 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
