Question about Magellan RoadMate 700 GPS Receiver
Intermittant Unit is suddenly intermittent. Sometimes OK, sometimes can't get beyond final blue screen. Did read many posts and have accessed secret menus: have reset data. Have also run test on hard drive whichreads ok. Do hear a slight rattle when shaking unit (haven't dropped it) Suggestions
Chuck that piece of S_it in the garbage and pack the whole can off the France. Hopefully you bought a replacement plan or equivalent when you purchased it. Brought mine back after 2 days of blue screen issues, Best Buy replaced with a 1G Garmin Nuvi. Bye Bye Magellan, you bunch of French pinkie raised ****.
Posted on May 13, 2007
  • Mind Crime May 13, 2007
    1G= $ 999.99 to be exact, with a $3oo.oo gift card for the balance of the $1300.00 bucks I paid for it 3 years ago!!
SOURCE:
I have a 200 1.6 glxi in thailand, have intermittant engine shut down, electrical as all goes off, sometimes instant re start, back fire, and away, otherwise start off the key whilst rolling, i have c
check the battery terminals and posts are shiny clean and tight. Check for loose wires and other terminals that may be dirty or loose.. Have the fault codes read
Mar 25, 2014 | 1998 Ford Laser
Intermittent
Rutabaga, The most common reason for intermittent power is a small IC chip on the backside of the I/O board which is attached to the rear housing of your unit. If your unit's warranty has already expired I would recommend the following. This is at your own risk. Grounding yourself is recommended. 1. Take off the antenna by rotating it as far counter-clockwise as possible (all the way up) and pull it off. 2. Take out 4 screws 3. Hold both front housing and rear housing with and gently pull the two housings apart. Once it's barely opened unplug the RF cable attached to the corner of the main board. It will either be gray or black depending on when it was made. 4. The other end of the RF cable is connected to the I/O board attached to the rear housing. This is the board that has the small IC chip that rubs against the rear housing which causes it to come off. 5. There are 6 or 8 small screws holding the I/O board to the rear housing. Remove them. 6. Once you got it off, look at the back. On the bottom backside of the I/O board next to the metal heat shield there should be 3 small IC chips. The lowest one is the one that rubs off. If the IC chip is present try looking at it through a magnifying glass and even push it a little bit to make sure it's not loose. If the IC chip isn't there, then look around for that rattling piece. (Either way I suppose look for the cause of the rattle) Soldering: If you find that the IC chip is loose, then you will need to solder it back on. This is not a lead-free unit therefore you can use lead. If you do not feel comfortable doing this, then atleast you have found the problem and can take it to an electronics shop for them to solder it back on. If you feel comfortable doing it, then by all means knock yourself out. If you have any further questions then please ask before proceeding. -Daniel
Jun 29, 2007 | Magellan RoadMate 700 GPS Receiver
Dryer heat won't come on every time. Sometimes
That is probably some burred contacts inside the timer. Most timers cannot be serviced but this timer can be if you are handy and careful. You can file down the contacts in this timer and it will work ok for a while and if it keeps on being intermittant you know you gotta buy a new timer. It is simpler and cheaper just to clean the contacts though.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2010 | Dryers
My FP7317 sometimes goes off and I can't get it on again. After removing AC power for some minutes and powering it up again the monitor works fine. Sometimes for some minutes, sometimes for hours. Any help...
alexanderdeu, All you need to do is INSPECT the printed circuit "switch-mode-power-supply"/"CCFL inverter supply" board, and do a bit of reading/research and you will know exactly what to look for and how to correct the "intermittant black screen" problem. If warranty on unit is valid, USE THAT FIRST!!!! If warranty not option then read more of my FIXYA profile to learn about all other options you have. Your CCFL backlit monitor no different than any other brand!!! Visit other web links you find in profile and watch some of the longer and more USEFULL video clips found on YOUTUBE. Hope this gets you started on DIY repair of your unit. If this response helps, please return to rate it on FIXYA. Good luck guy!! 12fixlouie
Jan 09, 2010 | Compaq FP 7317 17" LCD Monitor
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Dan
Oct 19, 2009 | Panasonic Televison & Video
Hi, I have a Vizio P42. Worked fine for 5 years. Today is has a vertical blue stripe 1.25" wide, 4" from left side of screen. Blue stripe remains even if all inpust cables are removed. Problem is...
it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
Oct 17, 2009 | Televison & Video
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Zenith E44W46 Audio works - intermittant picture
i hava a Zenith Model # E44W46LCD telivision. There is a light blue line about an inch or 2 wide running across the bottom of the screen. The TV is about 4 years old. It doesn't get a lot of play probably less than 10 hours a week. can you help me
Jul 18, 2008 | Zenith E44W46LCD 44" Rear Projection...
Basslink intermittant
i posted similar prob. servo lights when power is being cut to speaker (over drive) and manual shows it for purpose of tuning gain. it should flicker at highest input only...mine is on always too. infinity wasnt much help since mine is out of warranty.
Nov 13, 2006 | Infinity BASSLINK Car Subwoofer
Magellan RoadMate 700 GPS Receiver Logo
60 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
