Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Dark picture problem
Hello, I have a mitsubishi dlp rear projection tv that has a very dark picture. We have replaced the bulb, some of the capacators and cleaned the mirror and the picture is still very dark. Any ideas as to what else could be wrong with it?? We got the tv used and it is likely 3 years old.
Help please!! I am having the same problem ,my picture is very dark. I did not buy the new bulb from mitsubishi though. I found a company that sold them cheaper! Maybe you get what you paid for!
    Problem Solver:
  • 11 Answers
There are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Posted on Jul 07, 2009
Tv is getting dimmer
Brenda, Your projection bulb is about to die. Go on eBay, so a search for the bulb. Only buy a genuine Mitsubishi bulb to replace it. Or order one of these;http://www.shopjimmy.com/mitsubishi-wd-65c9 Get one of the "assemblies".
Removing and replacing the bulb unit is SUPER easy. Unplug the TV!! You unscrew the one screw on the litle door and the lower right, back side of the TV, then unscrew those two screws that hold in the unit, and slide it out. Slide in the replacement, and tighten everything up. Put the door back on, and plug it in.
Nov 25, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
May 27, 2011 | Mitsubishi WD-65738 DLP TV
I have a mitsubishi 60 inch tv model wd-60c9 and i purchased it this year ..aug 06 2010 and the picture has became very dark..i am using hdmi conection and purchased new and better cables..issue still dark
The tv projection lamp have problems,it shorting out some how.That why,u have a dim picture.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.New tv,call mitsubishi for a warrenty repair.
Oct 18, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Feb 19, 2009 | Samsung HL-R5668W 56" HDTV
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Nov 21, 2008 | Samsung HLP4674W 46" Rear Projection HDTV
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
1,539 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
