Question about Sony Cyber-shot DSC-W50 Digital Camera
Wickedwahine Just today, the directional buttons froze up so that the up/down, left/right arrow buttons no longer work to scroll through pictures nor can I use them to navigate menu items. I removed the battery for 1 min as suggested in troubleshooting but it still didn't work. I also tried to press and hold the control and power button (just a guess) trying to trigger a reset. The directional buttons worked very briefly after that but it might just have been a fluke.
  • tmpacheco Jan 02, 2009
    Thanks, jerryg50.
    The camera was not dropped. I hoped that the problem could be solved with a reset. It's acting like a computer that froze up.
    I also wonder if it's hanging on some pictures on the memory card that may have become corrupt?
    Genius:
  • Sony Master
  • 1,667 Answers
This may be an intermittant on the circuit board or the switch assembly inside of the camera. Was the camera dropped?
I would not suggest trying to fix this yourself unless you have experience in this type of service and have spare parts.
Jerry G.
Posted on Jan 02, 2009
  • Jerry Greenberg
    Jerry Greenberg Jan 02, 2009
    You could try another memory card if you think that the memory card is defective or corrupt. I have never seen that type of fault without the camera reporting a memory card failure.
    Jerry G.
  • Jerry Greenberg
    Jerry Greenberg Jan 10, 2009
    To prove your theory, try another memory card to verify if the card is the cause of the fault.
    Jerry G.
No live view nikon d90 camera
Push your camera's settings button (next to top button to left of LCD) and, using the left, right, up, down arrow keys, scroll down to the "Custom Setting Menu". Scroll down to "(d)Shooting/Display". Push the right arrow key and scroll down to "( c4)Monitor Off Delay". Push the right arrow key again and you will be able to choose set the delay between 4 seconds and 10 minutes.
Mar 28, 2014 | Nikon Cameras
Tip
How to reset Canon MP600 printer to the factory settings?
1. Press the HOME button.2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the button.
3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the button.
4. Use the Easy-Scroll Wheel (B) or the up / down arrow to select [Reset settings], then press the button.
5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press .
6. Press the button to return to the HOME menu.
This will help.Good Luck
on Mar 10, 2010 | Office Equipment & Supplies
I have a canon MP600 printer and the language has changed and i can't read it now and do not no how to change the language back to english
Jun 22, 2011 | Computers & Internet
I unfortunately do not have the remote or the manual, is there a way i can increase the screen size of whats playing? its coming up square, with 2 black bars on the sides. id like to go full screen.
Without the remote, press the Menu button on the side of the TV. Select Picture Mode and then scroll to Screen Format (second item) and select that. Use the left right arrow to try different formats. Press Menu repeatedly to exit the menu system.
Use the ch + and ch - buttons to go up and down. Use the Vol + button to mimic the left arrow and the Vol - button for the right arrow. Press Menu again to select an item or for OK.
The manual is available from the manufacturer. The direct link for the English version is: http://support.ttetech.com/RCATV/Assets/PDFs/L32HD31_E001A_IB_e-08.pdf . If the direct link doesn't work, start here: http://support.ttetech.com/en-us/productdownloads.html and use the drop down menu to select 32" TV and then L32HD31.
If you would like a replacement remote, try here: http://www.rca.newremotecontrol.com/catalog_item.php?catnum=275576 . Otherwise, most universal remotes will work the basic functions if they were programmed 6 months or more after the TV was released. However, you probably will want one that can match the Format (Left arrow) button as well as the input button. This probably will not be available in the most basic universal remotes. (It is guaranteed to be in those remotes that can be programmed through a USB connection to a computer.)
I hope this helps.
Mar 04, 2011 | RCA L32HD31 32 in. LCD HDTV
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
RGB Histogram will not turn off.
It's not hard... I had the same problem, but I found this solution on the internet and it worked.
First turn on the camera and press the play button.
You are now viewing your picture with the histogram.
Use the same joystick looking kind of button that you use to scroll left and right through the pictures, but instead of going left and right, go UP OR DOWN. That scrolls through the different display settings.
Hope that helps!
Dec 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
How do i get brighter pictures
There are only two options for adjusting the brightness of pictures in this camera, exposure and flash setting.
1. Flash Options: The flash is off by default. To turn it on you must press the button with the crooked down-arrow label between the DISP and MENU buttons, and the flash status will display in the top right-hand corner of the display screen. OFF displays the crooked down-arrow and a circle with a line through it. Press the button once for AUTO, displays the crooked down arrow with an "A" next to it. Press the button once more to force the flash, displays the crooked arrow only in the top right-hand display. Regardless of mode, the display will blink rapidly while the flash is charging and remain solid when it is charged and ready for use. Keep pressing the crooked down-arrow button to scroll continuously through the three OFF/AUTO/ON options.
2. Exposure setting: Press MENU, then the left arrow on the top right-hand four-way button on the camera until the COLOR menu is selected. Scroll down to EXPOSURE and press the MENU button again. You will see EV on the display. Use the up and down arrows to increase or decrease the exposure setting. 0.0 is default, you can go up to +1.5 or down to -1.5. Press MENU to exit when you're done. +1.5 would be the maximum brightness setting.
Oct 13, 2008 | VuPoint DC-M306AT-VP Digital Camera
How do i get rid of replace lamp message & reset lamp timer
If you are using the RM-PJ2 remote control, following these instructions. You will have 5 seconds to complete the key sequence.
1. Make sure the Projector is in "Standby" mode. There will be a red light instead of green
2. Press the Reset button
3. On the "joystick" type button, toggle the left directional arrow
4. On the "joystick" type button, toggle the right directional arrow
5. Press down on the "joystick" button to press Enter.
6. Your lamp hours should now be reset.
Recap: Reset, left arrow, right arrow, Enter, all within 5 seconds.
Mar 26, 2008 | Sony VPL-EX1 Multimedia Projector
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Sony Cyber-shot DSC-W50 Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
