Question about Philips 32PFL7332D 32 in. LCD HDTV
How do you turn the Ambilight on our philips tv?
Model number 42ta648bx/f7 and there is nothing in the owners manual except that it does have an Ambilight. How do we turn it on???
  • 2 more comments
  • Cbaity Jan 06, 2009
    How do you turn on Ambilight on Phillips TV???? Help!!!!
  • brui Jan 11, 2009
    i cant do it either theres nothing in the manual
  • verymarried Mar 02, 2009
    Having the same problem. Thought it was a cool effect ON THE BOX, now I have NO idea how to turn it on. Are we that stupid or are the too smart for their own good, assuming we would know how to do this?
  • Anonymous Mar 24, 2014
    Hello
    I have a problem with Ambilight. Every time I switch Ambilight TV program asked me whether I want dynamic or static Ambilight? It is very disturbing when shifting TV programs. Who knows may be the solution for this problem?
    Thank you
Hi guys, I have the same model, and after reasing the manual a little closer and skimming the setup menu I've discovered that it's not actually a built in ambient light, it's actually a setting in the picture menu under "active control" that measures the ambient light in the room and adjusts the picture quality accordingly to ensure the best contrast and reduce glare/reflect imaging. Hope this helps....
Posted on Mar 22, 2009
Phillips 42ta648bx/f7 LCD tv won't power up. The power light will come on and go out imediatly. No picture, no nothing on the screen. not even a flicker. I'v tried to reset it by unplugging it but no
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 10, 2015 | Televison & Video
I have a Philpis 42" LCD TV Model # 42TA648BX/F7. Basically, I know the Power supply board is bad (it was not functional when I aquired)). Obviously someone previously had it diagnosed and got sticker...
Appears that the only other major component is the Servkit assembly
http://www.partstore.com/Model/Royal+Philips+Electronics/Philips/42TA648BXF7.aspx?SearchTerm=True
Sep 28, 2010 | Philips 42TA648BX 42 in. LCD TV
I have a kenmore wall oven that flashes f7 every time we try to use it. and it turns itself off right in the middle of cooking and starts flashing the f7. Help !!!!
Kenmore recommends this:
The display of your control is flashing "F" followed by a number or letter. Oven malfunction. Press the CLEAR/OFF pad. Let the oven cool for 1 hour and place the oven back into an oven operation. If the problem repeats, call for service. 1-800-4-My-Home.
If you state the model #, I can look up the owner's manual for you and give you the link. Let me know.
May 22, 2010 | Ovens
We bought a new phillips moderl #22PFL3504D/F7 tv.
You can download the manual as a PDF here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=22PFL3504D/F7&slg=en&scy=US
There is also a link to Parts and Accessories on the left hand side of the page. Follow the link and enter your model number to get a replacement remote.
You can also buy a replacement remote at remotes.com:
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12743739505150&smodel=22PFL3504DF7&brand_pn=PHILIPS_22PFL3504DF7
I hope this helps.
May 20, 2010 | Philips Televison & Video
50 in philips hd plasma with ambilight model number 50PF9631D/37
The x-sus and y-sus panels have some fuses,check to find out wich panel is broken and replace.
Sep 04, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
50pf9631d ambilight has gone out on one side, how do I repair it with out paying philips (or an authorized dealer) outrageous rates, for a problem that has clearly affected MANY Ambilight owners? This is...
ok its possible it is the light itself which would be cheaper- or- it could be the ambilight driver- each ambilight has a driver that tells it to turn on supplys power etc-its not difficult to change-usually located on either one side and the lights all run from it or one on each side-depends- its small rectangular and you can follow the wire from the light back to where it plugs in to the driver- try shopjimmy dot com for parts
Aug 18, 2009 | Televison & Video
Sylvania console tv model cld246pe04
I have its owners manual. Contact me.
May 15, 2017 | Televison & Video
Philips 32PFL7332D 32 in. LCD HDTV Logo
1,101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
