Question about Asko W6021 Front Load Washer
Asko 10505 washer will not spin
My 8 year old ASKO washer will not spin, everything else works. I have isolated the problem to be either the circuit board or the motor (the brushes are fine). I desparately need a circuit diagram to test the voltages on the board to confirm if it is the board.
Will pay for a copy if available. The last repairman stole mine from the machine.
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
Macmarkus
  • 2605 Answers
SOURCE: asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Posted on Nov 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Replacing Motor Brushes, what needs to be done to
To clean the commutator, or armature as it is usually called, simply rub it with a piece of emery paper, or sandpaper, turning it by hand to ensure you clean it properly..
You need to remove the motor to do this of course.
Please rate my solution.
Thanks.
Posted on Nov 12, 2009
  • 1768 Answers
SOURCE: asko 10505 will not spin
Your washer unit is needing a new timer and replacement is needed if the part is available.
This will require some electrical experience to replace the timer unit or go to your local Sears repair and they will come out and repair your unit for a fee.
Posted on Jan 29, 2010
SOURCE: Asko 10505 door doesn't open
It is very likely a drainage problem. Please see this link:
http://www.fixya.com/support/t427982-asko_10505_wash_finished_door_open
Posted on Apr 02, 2010
Asko 10505 Washer will drain but will not spin. Initially that was the problem, but then in trying it out again the washer will fill with water, will drain but will not even wash now. Do you think it is...
You don't mention if the drum spins if you choose the spin program, if it doesn't it could be the brushes on the motor. This would be a cheaper option to try first rather than a board. sometimes you can clean the com or tap the brush carriers gently and get the motor to spin on an empty or small load.
If you're confident, with the power offer and machine isolated you can check the resistance across both the brushes and slowly rotate the motor as a test.
hope this helps
Mar 12, 2013 | Asko Washing Machines
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
Unable to locate any info on a model 10505 se # 982410041588
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
Mar 17, 2010 | Asko Dishwashers
Asko 10505 will not spin the belt is not broken, tub fills and drains
Jan 29, 2010 | Asko Washing Machines
Nov 01, 2009 | Asko W6021 Front Load Washer
Leaking inlet valve on Asko 10505
Unfortunately, the only way to be 100% sure this won't happen again is to replace the inlet water valve. Especially if the problem is intermittent. You could live with it if you turn off your water taps when the machine is not in use.
Feb 19, 2009 | Asko W6021 Front Load Washer
Repair front load washer
wash machine not draining properly at end of wash. not fully spinning.
pls advise
Sep 11, 2008 | Washing Machines
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
41 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
