Question about RCA HD52W59 HDTV Projection Television
My t.v. looks like its in 3-d
I have a 52 inch projection t.v from rca model number hd52w59 and all of a sudden today it looks like its in 3-d. Is this fixable and not really expensive or should i just buy another t.v..
    Genius:
  • 1,030 Answers
You have a convergence problem. First question does the picture curve in at top and bottom> Convergence is common problem. I see this problem all the time at the shop. NExt question. IN setup part of menu do you see an option called convergence if you do not this could be a easy enexpensive repair cousult "the fl231 problem" under tips and tricks if you do not have the convergence option. if you see that option then it could be one of three diffrent cuircit boards.
Posted on Jan 06, 2009
    Scholar:
  • 90 Answers
The cost I don't know, but this can be fixed. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Posted on Jan 02, 2009
My 52" RCA projection, model
comon fault is one of the picture projection tubes is broken.not worth fixing
Mar 29, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA 52 inch rear projection tv. Model # HD52W59 The blue CRT is arching inside the tube and I get no picture on the TV at all. Is the blue CRT gone bad
Yes,the blue CRT is dead,arching indicate the high voltage not going through the CRT tube anymore.Try website like Tvrepairworld.com,check if u still can buy refurbish crt tubes.
May 23, 2010 | RCA HD52W59 HDTV Projection Television
All of a sudden the picture went out and there is no sound on my RCA HD52w59 it is 4 years old
Thats usually a problem with the deflection board. You can get a replacement deflection board from www.tvrepairworld.com call them if you dont know which board your model uses.
Dec 20, 2009 | RCA HD52W59 HDTV Projection Television
Circuit Board
try union electronics. thats where we get most rca parts for my shop.
Oct 11, 2008 | RCA HD52W59 HDTV Projection Television
RCA 52 inch HDTV
Hello Rebecca197,
What part did you remove? and what numbers are you trying to find. post them, and I might be able to do a cross reference.
Thank you,
Hello shainer,
It sounds like you have a power supply problem, check the fuses on the AC board and the check the voltages on the main PS board.
I hope this helps.
Thank you,
Shuttle83
Jul 11, 2008 | RCA HD52W59 HDTV Projection Television
Lcd tv
Is the correct model number HD52W59? Let me know as if the model number is a different one I may be able to help. As the 52W59 wont be available except maybe through RCA
May 03, 2008 | RCA HD52W59 HDTV Projection Television
Part number
you must have what known as yx extension it will be on the label in small letters hd52w59...yx1 yx39 or something like that
Feb 19, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
