Question about Magellan Roadmate 760 GPS Receiver
Overheating Hi Dan I have a 2nd hand Magellan 760 for about 6 months now, it seems to day it might be overheating and causing the screen to freeze up (presently it is windshield mounted and outside air is 86 deg)It freezes up on different screens and will not let me power off from the button I have to take power away to re-boot, The back of the unit felt hotter then usual. any hints if I am correct in my assumption and better yet any fixes?Thanks Jeff
    Novelist:
    Scholar:
  • 86 Answers
Another way to turn your unit off is by using two hands.. press the power button, enter and cancel at the same time... not that.. that fixes your problem.. just fyi. I haven't directly had experience with these units in high temps but if I were to have a unit that freezes up in the middle of navigating, I'd set my sights on either the software or hard-drive. So that said, is your unit completely freezing up as in there is no reaction to pressing any buttons? What about when you scroll the volume knob.. do you hear the clicking noise? Does the power off method I said above work? If any of the answers are yes, then that would exclude the main board from being your problem. As far as the heat issue, I would suggest trying a different cradle first, then I would dive into the guts of the unit looking at a small IC chip on the backside of the I/O board (the board attached to the rear housing) making sure that one of three small IC chips in a row aren't rubbing against the outer housing. Let's try not to get into this depth yet and go off your response for now.
Posted on Jun 07, 2007
  • Daniel daniel
    Daniel daniel Jun 29, 2007
    thanks for the rating JPZ!
SOURCE:
1998 Honda Accord. I was driving the other day in 100 degree temprature and my car started overheating when I was at an idol. My air was on and blowing cool air, but my car was overheating. I turn
Hy Pls do check your fan motor in your engine bay mounted on the radiator, check for the 2nd fan speed is running during the temperature is almost half. When u first switching the unit, the a/c fan is running, then at certain temp the fan motor is running faster(2nd speed). If u dont get any changes in motor speed then u have to replace a 2nd hand fan motor. Good luck
May 07, 2012 | 1998 Honda Accord
My laptop freezes at hp screen with F10 to enter ROM Setup, so I hit F10, and after about 3 minutes a black screen appears with a blue screen saying drivelock multibay password in it. Sometimes it just...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after just after you switch On until you get Safe Mode Option.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Jul 30, 2011 | HP Compaq nc6220 Notebook
Overheating, leaking antifreeze
Overheating can be caused by leaking anti-freeze, where do you see leaking at? also if fans not coming on can cause overheating and leaking out overflow do to hot? Tell me more so I can help more, which motor you have and more of what its doing
Feb 07, 2010 | 2001 Oldsmobile Alero
I have a aspire 4520 acer laptop that sometimes freezes up with a white screen and what looks like an equal sign types of lines going through it. kind of in a pattern from one corner to another. it also...
Hi
the freezes and lines is most likely the video card failing, or overheating, or damage from overheating.
Its a common problem with the acer aspires, what can you do about it? Vacuum the dust out form the fan or use canned air to blow it out, there will be a lot of it.
Try one of those cooling pads that goes under it.
depending on how bad the problem is with the video card which in most of these laptops can't be user replaced. Got warranty? It might help or might not help at all. That is generally caused by poor cooling and dust in the fan heat sinks so the air doesn't flow and too much heat being generated by the board and its components eventually damaging the video card or the motherboard.
About the 2nd problem, its mainly caused because of your hand touching the touch-pad try a news paper on top of the touch pad or a usb keyboard and see if that problem goes away.
May 17, 2009 | Acer Aspire 4520-5582 Notebook
Game Saints Row 2 keeps freezing at certain points in the game
maybe you should try different games? see if those different games freeze, if so, then it might be your blu-ray player in your ps3, or your ps3 might be overheating. my games froze at certain points because my ps3 was overheating, just try a few different games
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
I need an upgrade for my magellan Roadmate 760
You can download an upgrade for this unit from the Magellan website for free. Maps can be upgraded but they cost about $80, and that doesn't seem worth it to me. See if that works for you.
Dec 13, 2008 | Magellan Roadmate 760 GPS Receiver
Lc prado overheat cause?
The turbo will not cause overheating.
Check the thermostat in the cooling system is working and then smell the coolant with the engine running. If you smell exhaust gases in the coolant it could be the head gasket.
Nov 21, 2008 | 1993 Toyota Land Cruiser
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
MAgellan Rodmate 760
You should return it and get another one.
Jun 15, 2007 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
140 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
