Question about GE WBSE2090A Top Load Washer
GCXR2080T knob broken, where do I get a new one?
    Top Expert:
  • GE Master
  • 9,472 Answers
Posted on Oct 22, 2012
SOURCE:
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
Ge wpsq3120t2ww I have a broken control knob, how do i replace this?
Knob(s) on left side of machine just pull off. Make sure the metal D clip comes off too. Push new knob on.
Timer knob: Pull knob out and remove nylon clip off back side of knob. (use a thin screwdriver to push it off, or a thin needle nose plier to pull if off) then knob pulls off easy. Push new knob on with clip already in place. Easy.
Jul 08, 2009 | GE Profile WPSR3120WWW
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
How do i remove the knob for a 1988 911 Porsche headlight switch? The shaft has a hole to hold it from rotating so i assumed the know screws out. I tried this, the knob rotates but does not come off....
hello jesse
the knob is most likely broken you need to take it off and get a new one, the threads on it are broken-striped,use plyers for the job,but safe the "light "logo new switch -knob -does not come with it..
proporsche
Jun 15, 2009 | 1985 Porsche 911
Knob broken
go to this site and you will be able to order a new knob.
http://www.repairclinic.com/0047_13.asp
Feb 11, 2009 | GE Kitchen Ranges
Broken lid knob
you can try a "home improvememt store" remove the old one and replace with a kitchen cabinet knob that screws on
Jan 30, 2009 | Faberware FRA100A 10-Cup Rice Cooker
GCXR2080t - top load washer problem
direct drive has broken simple 3 dollar part and changing out is simple turn washer over after disconnect take out motor you will see this part
it comes in 2 parts they both fit together this is direct drive
put back together way you took out motor too and then turn upright connect everything and turn on washer this should be the problem
also since your down there under washer replaceing part get appliance oil and oil all major movable motor mechanical parts
Jun 10, 2008 | GE WBSE2090A Top Load Washer
Broken knob
you can probably get a substitute knob from radio shack - replacement knobs. it may not have the markings you desire but at least you'll have a knob you can rotate.
Dec 25, 2007 | Crock Pots & Slow Cookers
Drying time knob broke
You should be able to simply push the new knob right on the switch shaft. If part of the broken knob shaft is on the switch, remove it first before installing the new knob. If you see that the switch shaft is broken off, replace the switch as well. Hope this helps.
Aug 07, 2006 | Hotpoint Aquarius WD63 Front Load...
GE WBSE2090A Top Load Washer Logo
43 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
