Question about Baby Lock Ellure
My ellure machine has got its auto safety lock on. i have changed the needle and there is no thread tangle in the bobbin case. the upper needle carriage is jamming as though there might be thread stuck in the upper threading circuit. HELP!
    Habit-Forming:
  • 64 Answers
Remove the throat plate and see if there is a 'bar' in front of the feed dogs. Try to gently push this to the LEFT until only about 1 inch of it shows. This happened with my machine last week.
Posted on Sep 18, 2012
I have 1994 airostar van 4.0 spark knocks on regular gas also scaned sead had slow injector puls
Posted on Jan 02, 2009
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
Bobbin thread tangled
Try these suggestions and see if they help
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Dec 22, 2013 | Baby Lock Ellure
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Aug 20, 2013 | Baby Lock Ellure
CONSTANT Check upper thread warning on a Babylock Ellure
try changing the needle
check for burrs on the needle plate and in the bobbin area
if the problem persists then the machine may have to be checked
again
Nov 26, 2012 | Baby Lock Ellure
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Thread continues to tangle on Ellure Plus even after changing out needle, bobbin, etc. Noticed that a small 'bar' was across front of feed dogs-pushed this back to the left but problem contin
Your post made me laugh with the funny bone remark. :) I'm glad you found and posted a solution to your own problem. Bravo!
Happy sewing.
Sep 15, 2012 | Baby Lock Ellure
I have a ellure baby lock sewing machine. It will sew fine for a while and then the bobbin tread gets tangled up and breaks the needle thread. What should I do?
first change the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is not to full
make sure the bobbin is inserted correctly & turned correctly in the
bobbin case
make sure there are not any burrs on the needle plate
make sure there are not any burrs on the bobbin case
Jul 09, 2012 | Baby Lock Ellure
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jul 27, 2009 | Baby Lock Ellure
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Sewing Machines Logo
213 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
