Question about Polaroid 1720-7 Remote Control
Polaroid 40" lcd TLX-04011C
I have a Motorola MOXI DVR receiver hooked up to my polaroid flat screen via component cables. I'm currently using the moxi remote for the channel guide and the polaroid remote for the volume. This may seem like a minor inconvenience to some but it is a major complication for me. On my Polaroid remote it looks as if it is set up for DVR controls. My question is, is there a way to program my Polaroid remote to work with the MOXI DVR receiver? (my cable provider is Charter Communications I work for Charter also)
  • tazaraz23 Mar 10, 2009
    I have the 32" Polaroid TDA-03211C and not happy about using two remotes. Neither Charter or Polaroid seem to have a fix that I can find.
  • Anonymous Apr 23, 2009
    It looks like MOXI needs to talk to Polaroid because I'm having the same problem
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central 2. Settings
3. Remote Control 4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
Posted on Mar 11, 2008
pishta68
  • 579 Answers
SOURCE: remote control does not work
Look at the IR emitter in the front of the remote through a digital camera, if it blinks, you have the wrong code. If it doesnt, you have a bad remote.
Posted on Nov 30, 2008
  • 360 Answers
SOURCE: My Polaroid remote control won't work.
First we need to know if the remote is working. Heres the "secret" way to check a remote. Use a cell phone w/camera.
  • Set the cell phone to camera
  • while watching the camera screen and a known good remote, aim the remote at the lens and press a button (volume works well) on the remote (not a device button ie; sat,tv,vcr,etc). You should see lights turn on/flash. Now you know your camera can detect IR light.
  • Do the same again with the remote in question. If there is no IR light output, the remote is the problem. replace the batteries, ensure good battery contact, retest the remote.
If the remote is working then the problem is in the unit.
Let me know what you find.
Neat trick, huh? Please take the time to rate this.
clarkco
Posted on Feb 10, 2009
SOURCE: The remote won't work direct TV
try 1991 or 1992
Posted on Apr 16, 2009
SOURCE: Directv codes Polaroid RC-201 remote.
remot control dream box s500 code
Posted on May 19, 2009
Polaroid tlx-01911c hdmi with laptop says not support!
You either lost HDMI on the TV or the Laptop. The way to tell is hook up the laptop to another set aand see if it works. If it does than the problem is in the Main PCB of your TV.
Apr 10, 2012 | Polaroid TLX-01911C LCD TV
Tip
Polaroid TLA-04011C Service Manual Download
Polaroid TLA-04011C LCD TV Service Manual Download
Have you misplaced your Polaroid TLA-04011C LCD TV Service Manual?
Would you like a digital, searchable version of the Polaroid TLA-04011C LCD TV Service Manual?
Follow this link to download a digital version of the service manual.
I hope that helps.
_________________________________________
Polaroid TLA-04011C Manual Download
on Apr 26, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Tip
Polaroid TLA-04011C LCD TV Users Manual Download
Have you misplaced your Polaroid TLA-04011C LCD TV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid TLA-04011C LCD TV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________________
I have a Polaroid 40" HD TV TLX-04011C while
There may be an issue with "cold" solder joints on the power supply board, or there may be a failing component on that board as well.
Some things to look for also are bad solder joints particularly on the fuses of the inverter board or boards depending on production run. Those are going to be rectangular items marked with "8A" on them near where the multiwire connector attaches to that board under the plastic cover. As well as any bulging electrolytic capacitors. Since there usually more than one in parallel if one shows as bad- replace them all
A can of cold shot help locate the specific area or component of the 24 volt section of the power supply that is the issue.
Nov 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid TLA-04011c 40 inch. LCD TV? How can u fix TV plasma screen? my friends kids hit the tv screen for with wii remote. i think they broke the tv screen from the one side. and how much it cost to fix...
Sorry this tv can't be fix acept replaced the whloe picture screen panel itself,the tvs screen panels are in of the limited production by the tvs industries,only can buy picture screen panel from the tvs themselves and it 90% important to the tv,will cost u the same as a new tv to get picture screen replaced.Sorry doesn't worth as a whole tv anymorre the tv now only worth as salvages tv for it electronic boards for spare parts for other tv,that it.
Dec 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid tlx-04011c shuts off by itself but blue light still stays on..sometimes stays on for a while but eventually shuts off
The problems is the Tuner board.That the board,where the coalax signal cable plug into it to get the broscasting signal.Tries Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 15, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
WHERE CAN I PURCHASE THE ORIGINAL STAND FOR MY POLAROID TLX-04011C
Try websites like Ebay.com,Amazon.com to buy many kinds of refurbish LCD tvs bases.
Apr 28, 2010 | Polaroid FLM-4234BH 42 in. LCD HDTV
Televison & Video Logo
427 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
