Question about Canon PIXMA MP510 All-In-One InkJet Printer
Co mputer says printer is offline, but its all plugged in and looking normal - any ideas? L
  • 66 Answers
Hi Lander,
Try to make it online on your computer. Click on Start|Settings|Printers and Faxes. Right click on the printer driver and select Use Printer Online.
If this still does not work, try to connect printer to another USB port.
Rgds
S88
Posted on Jan 02, 2009
Mputer does notwork muouse does not work!!!!!!!!!!!!!!mouse that came with this brand new co
Test it with a live bootable linux cd or dvd or usbdrive instead of the pre installed software .
To look if its the pre installed software or the hardware.
Nov 26, 2016 | Computers & Internet
I have no instructions to build my power pro multi gym can anyone help danny9111@hotmail.co.uk just cable problems ty .
Sometimes when you want to print a document, you choose "Print" and select your favorite printer but nothing happens. You look at the printer menu and encounter the pesky "Printer Offline" message. You can get your printer back online in no time. www.rubberflooring-direct.co.uk
Aug 18, 2013 | Exercise & Fitness
Says disconnected but it isn't
I have put together a couple off guides for troubleshooting different offline printer issues for Windows XP, Vista and 7. I would recommend checking them out here: http://www.refreshcartridges.co.uk/igloo/how-to-make-your-offline-printer-online/
Hope they help.
Apr 12, 2013 | HP Photosmart C6280 Printer
Do i need a usb cord connected to my co mputer to my pixma-mp280 canon photo all in one when i install the disk
Install Drivers and sofware first. Then reboot your pc.then plug your usb in to your pc and connect your power cord to your printer. turn your pc on and your printer, all should work well.
You will need a usb cable so your pc can talk with your Printer.
Hope this helps.
Apr 03, 2011 | Canon Office Equipment & Supplies
Our hp color laserjet printer is not printing... all the ink cartridges are new and inserted correctly... we have no idea what's wrong
There can be a number of things that are wrong so bear with me as I list some suggestions or possible solutions.
Always, ensure that your cables are securely connected between the PC/Printer and your AC Power cord is securely plugged into the outlet as well as the back of the printer. Additionally, make sure that the printer isn't indicating an internal problem such as low toner, paper jam or some error code on it's display. If everything on the printer appears to be normal, proceed to the next paragraph, If there are any error codes or messages on your printers display, you'll need to look those up to clear those issues before proceeding.
Open your print queue in your computer, (Control Panel > Printers> HP Color Laser or name of your printer) verify that your printer is seen as the "Default" printer and that it isn't currently selected to work "Offline".
If it shows that it is the "Default" printer, and it is NOT selected to "work offline", then let's try the next step. If for some reason it isn't the "Default" printer, you can select it to be so. If for some reason it shows that it is "Offline" uncheck that selection.
Under your printer "Properties" (right click on your printer, bottom selection on the drop down menu) you will have a "Self Test" button. Click this button (only once), observe your printer and see if it prints a test page.
If your printer shows no error messages, all cables are secured (always double check), your printer doesn't show it is offline in the printers queue, it properly prints the test page then at this point it should be working correctly.
If the steps I have mentioned above don't work, please provide more detail as to the printer model, any changes that you have recently made (software installed, cartridges changed, etc.) and we will find you a solution.
Aug 31, 2010 | Computers & Internet
Comes on for only a second or two. Checked all
You are more likely to have bad caps in the power supply, open it up and look for bad caps, worst case will be bad lamps. See example here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | LG 19" Widescreen Flat Panel LCD Monitor
Image runner 2230- computer not recognizing IP adress for scanner
you must be shore that the cable between the copier and the co mputer is cross cabel and connected if there is a switch put normal cable
and then be shore that the diference between the two ip.s is smal as the computer ip 192.168.1.20
and the copier ip 192.168.1.30
Apr 28, 2009 | Canon IMAGERUNNER 2230 Copier
OFFLINE PROBLEM
disconnect USB, go to RUN and type in services.msc and then find print spool and right click, then choose restart .plug in usb
Mar 02, 2008 | HP PhotoSmart C4280 Laser Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
109 people viewed this question
old marine
old marine
