Problem while recording a tv programme - audio automatically off.
Sir, I am using Adcom invuilt tv tuner card. It is working. Whenever I click the record button the audio is automatically off and there is no audio even after stopping the recording. When change the setting from PAL M to PAL B or something else the audio is back to hear only. I can not record the programme with audio.
  • Anonymous Apr 27, 2009
    sound when I watch a live program. No sound when I record a program? why?
  • 24 Answers
Which program are you using there are tons of them
most common is mute on minimze is on
ususlly found in options
Posted on Jan 02, 2009
Adcom tv tuner driver of multimedia controller
A driver can be downloaded from DriverGuide.com
http://members.driverguide.com/driver/detail.php?driverid=1281766&action=download
Also Supports: AD-TV878R - ADCOM TV/CAPTURE -, Bt848 Video Capture Device, Bt849 Video Capture Device BtTuner, Temic WDM TvTuner, BtTuner, Philips WDM TvTuner (PAL BG), BtTuner, Alps WDM TvTuner, BtXBar, WDM Crossbar, BtCap, WDM Video Capture, Bt878 Fusion Capture Device - Video Section, BtTuner, Philips WDM TvTuner (PAL I) Manufactured By: Other Companies, Brooktree Corporation, Conexant, Brooktree File Name: PCTV.rar (6.5 MB) -------------
If required register for free donload, driver is available on that forum
Kind regards
Jul 21, 2010 | Adcom GCD-750 CD Player
Tv-tunner cannot render audio capture stream
What cable connections are you using? HDMI has to be enabled on you motherboard (high def. audio), if its S-Vidio you must run a seperate and dedicated audio cable from headphone jack to TV.
My first gues would be to right click your audio icon on your desktop toolbar and check your playback and recording settings, make sure the tuner card is the source, hope this helps!
Apr 03, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have saa7130 tv tunner card and i also install successfully above card but i have not a programme to run tv progarrme through cable but programme compatible to run the tv programme
please check back drivers tv tuner which has been fixed, if it was running perfectly or there is a miss, usually if the driver installed again the tv tuner can be used again. or for more open jelasanya tv tuner application and click on help, there you are given instructions in its use ordinances. thanks.
Feb 27, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I WANT TO RECORD A RADIO PROGRAMME BY DOWNLOADING
Are you in the UK?
1 The easiest thing to do is to record it using a freeview box onto either a video or other recorder.
2 If that's not possible try listen again if on bbc.
3 It's difficult to record directly onto a pc without a tv capture card (and essentially doing 1 above) when you can set a timer to do it automatically.
4 if you don't have that you can connect the headphone output to the microphone input and use the Windows Sound Recorder to then recod the outpu
Nov 08, 2009 | Packard Bell Easy One Silver 2120 Notebook
AUDIO NOT GETTING RECORDED IN FRONTECH INTERNAL TV TUNER CARD
Dear Sir,
For every tv tuner card there is line out socket, use two sided phone plug one side of it connect it to the the audio out off tv tuner and another to the Line in socket of your PC,then go the volume properties increase the line in volume. It deffinately solves your problem.If you have any problem regarding this issue leave a feedback,we will glad to assist you
fbe63e4.gif Phone connector
Have a nice day
good luck
Sep 17, 2009 | ASUS K8V-MX Motherboard
have you checked the volume level bothy in the software of the program and the sound card contriol input is not set to mute in control panel of windows?
Jun 20, 2009 | Pinnacle Dazzle DVD Recorder
Recording TV programmes to a laptop
You'll need PCMCIA or PCI-express tuner card and recording software.
Apr 04, 2009 | HP Compaq Presario V2000 Notebook
Wharfedale DVDR24HD250 DVD Recorder When set up will not find any programmes on Automatic Programme Search (APS)
Products such as this will use an internal tuner to tune channels, this tuner will not detect your televisions freeview stations, to record from your television, connect scart out from tv to the scart in on the recorder, then select the scart A/V channel, use the television to select the channel you want to record, you will not be able to record 1 freeview channel and watch another freeview chanel as you only have 1 digital tuner (in the television) the recorder does not have freeview built in.. hope that helps
Mar 24, 2008 | Televison & Video
Driver you have is not compatible! try to down load a newest version!!! and look on sound manager if mute is off
Jan 21, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
