Question about Sony WEGA KE-32TS2 32 in. HD-Ready Plasma Television
Dead plasma screen, you responded
I don't know what you mean by "the lamp" I've got the set apart, see nothing visibly burnt, fuse by AC input to power supply is good.
    Problem Solver:
  • 4 Answers
Ahm lcd (liquid crystal display) isn't visible without light behind its screen... its like a flouresent lamp just found backside of the screen inside...
Posted on Jan 12, 2010
My panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and reconnect . A replacement of power cable or use another power outlet is another good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
Dec 10, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
Dead 42" plasma - power problems
that was good to know.. good luc on your work..
`micro
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
My dead 42" plasma - power problem
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Atombomb72 - 42" dead plasma
This is the correct fuse:
see www.digikey.com
digikey part number is F2668-ND.
Help! screen wxga LCD screen malfunctioning after ac.
It sounds like something came partially loose or was damaged. You can try that theory by taking it apart and looking. Or finding someone who can without charging you a lot. You'd be amazed what TV and video repair people can do. My guess is that it fell on its side, and a new LCD may be needed. But I agree that something may be done with it, as nothing is burnt or dead, as you said.
Mar 23, 2008 | Acer Aspire 5610 Notebook
Vizio GV42LHDTV - No video inputs
my 42 also went black, and the "vizio" logo in front indicates as if it is turned on, it clicks on and off, but just has no output on the screen, meaning not a black screen, just a dead, no image, even when the system has clicked on
I tried turning off, on, unplugging, letting it sit (kind of like a reboot wishful thinking), removed all connections in back, (nothing still, not even the blue screen) just nothing.
What a shame, I had the unit less than 6 months, and now this? I have work to do, and I can't get it done.
Feb 25, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Sony WEGA KE-32TS2 32 in. HD-Ready Plasma Television Logo
132 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
