you can unplug the unit for 2 to 3 hours and plug it back in. this my reset it. if not look and see if the red button on compressor is out. if it is press it in to reset it. try these befor you call someone. if this doesnt work it my be the capacitor that was shorted out. hope this helps you.....thanks eddy
PSS26SGRE SS- Just replaced the water filter, it worked fine for 2 days. Now, no water at all....
(More)
PSS26SGRE SS- Just replaced the water filter, it worked fine for 2 days. Now, no water at all. Thanks.
ge refrigerator with smartwater plus, can not install the filter cartride because the holder is...
(More)
GE REFRIGERATOR WITH SMARTWATER PLUS, CAN NOT INSTALL THE FILTER CARTRIDE BECAUSE THE HOLDER IS DAMAGED.CHIPPED.
GE Profile refrigerator model no pds22mbraww. Some times when the door is opened the inside light...
(More)
GE Profile refrigerator model no pds22mbraww. Some times when the door is opened the inside light and gages will not turn on. If you hit the side, shake the refrigerator or trip the inside switch, lights and gages turn on (compressor also starts). Manually pushing the switch may or may not turn on the unit. If the door is open and I bang on the upper panel around the switch, lights come on and the unit starts cooling. The problem just started and happens every few days, not continously. I have cleaned the power connectors at the lower bottom of the unit, but this did not fix the problem.
