Question about SanMax 1 Bay (HD338CB) FireWire (IEEE 1394), USB 2.0 External Drive Case
USB Connection Problems
I have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. Sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. I do not have this issue using the firewire connections. I don?t know if I have a problem with the SanMax or if it?s operator problems. Also, how large of a HD can be used and are firmware updates available. Thanks, Cat
Jackboy, that wasn't a very good answer and it is apparent you are unfamiliar with the SanMax HD-338 External Hard Drive Case which has BOTH USB and Firewire connectors.
I don't have the answer to Redfire's question, but at least we need to understand her situation. She's not getting USB and Firewire confused. She's simply saying that when connected as USB Windows XP has trouble "seeing" the drive and when using her firewire connection off of the external case, she doesn't have this problem and is wondering why.
Jim B.
Posted on Nov 12, 2007
    Genius:
  • 2,985 Answers
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
Posted on May 24, 2007
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: USB Connection Issues
Cat this is your earlier problem reworded - I can see now that this is a dual device. If you can use it that way in Firewire mode leave it at that. However - is it possible that this is a 'switchable mode device and you have not discovered the secret of how to. If there is anything like a manual with this check it thoroughly or get into the makers tech support team
HD-338-COMP external hard drive not mounting
It's likely your dealing with hard drive failure on your san max and you will need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Computers & Internet
2 TB G-Raid External Drive connected with Firewire cable is not recognised after Reboot my PC
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 16, 2012 | Acomdata USB 2.0 2 TB External Hard Disk...
I have a Hitachi Simple Drive Mini x 320 GB that I've been using as an external for my macbook pro. I have been using it without problems for over a month now, but last week it didn't eject properly from...
does the usb cable you are using have 2 usb plugs so you can plug it into 2 usb ports at the same time.
If not, you could try using one, sometimes my external HD will not work on some pc's if i just plug it into 1 port
Sep 10, 2010 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Sanmax hdd-338-cb usb drive is not being recognized
rlmahle
If the drive is not showing in My Computer then most likely the drive letter that it wants to assign to is already assigned to another device. The link below will show you how to change the drive letter on the device.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
May 01, 2010 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
Good Afternoon, I have an 64bit HP Pavillion System, brand new, with Vista Home Edition, I previously purchased a 1TB USB external HD Simpletech, works fine with XP, but not with vista, keeps looking for a...
there have been alot of problems in the past with vista not all external components are compatible with this program.i had the same problem with vista so i got rid of vista and started using windows xp home edition since then i have never had a problem with it not recognising any device i have added to my computer.i hope this helps.
May 06, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
Transferring data from a sanmax to my laptop w/vista premium
Lindy. Go to my computer on your computer and click on the harddrive. Then search within to find the programs you want.
Jul 06, 2008 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
SanMax portable drive suddenly, after 22 mths, not recognized by XP
may be partition table is mismounted,go to dos mode and run CHKDSK for your external drive .(press F8 after post and select dos mode)
ragards
prasanna
Dec 16, 2007 | Computers & Internet
May 23, 2007 | SanMax 2.5'' EXTERNAL ENCLOSURE KIT...
SanMax 1 Bay (HD338CB) FireWire (IEEE 1394), USB 2.0 External Drive Case Logo
247 people viewed this question
Top SanMax Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SanMax Computer and Internet Expert? Answer questions, earn points and help others
