Inoperative LCD TV
I have a Visco Model VSC-37V1 LCD TV, Serial #64437-102033. It began to fail gradually over a 2 or 3 day period. It was having trouble turning on. Pushing the Power button would turn the power light from Red to Blue (normal) but the LCD backlight wouldn't come on unless the power-up process was repeated several times. Eventually it stopped working completely. Now when the set is plugged in the Red power indicator light comes on and pushing the Power button will change the Power LED from Red to Blue (normal). However no backlight comes on and there is no sound or any normal operation. Pushing the power button at this point will not turn the set off (power light from blue back to red). You must unplug the set and then the process can be repeated but there is no normal operation. I have swapped the control board in the set with another know working control board and the symptoms are the same so the control board is not the problem. All power supply voltages have been checked and are normal. Any idea which board is the culprit here? I was referred to you by Nathan at shopjimmy.com. Thank you for your help.
    President:
  • 1,990 Answers
Welcome to Fixya! My Name is Travis! I have heard this Problem Before on Another Model. Turns out it was the Power Switch in that case. Yours has the Exact same Symptoms. Get that Checked and let me Know so we can go Further or if that is it.
Posted on Jan 02, 2009
My tv keeps flickin on and off. sometimes the remote works and sometimes it dont.what can i do?
Hello Malcolm,
That model is sold under several different names but the same model number. These units are well known to have issues with the power supply board and this can cause the exact symptoms you are having. The power supply board can easily be repaired, you just need to replace the defective capacitors on the board. Here is a link to a repair guide for the Visco TV that is the same as your Polaroid model. The repair guide shows what to look for and replace on the power supply board to repair it. I hope this helps.
http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/
BuddyMc
Jul 20, 2012 | Polaroid FLM-323B Television
I have a VISCO 32' tv & lost the remote. Model # VSC-32V1. I need a remote to use to get to the HDMI area. I tried a universal but it only turns it on & does channel.
Check the operation manual and note down the model number and go and fetch it from any electronics shop nearby. These are available freely now in the market.
Jul 19, 2012 | Televison & Video
My lcd element FLX-3711B dont turn on.. I plug the cord cable and only flashing front red light? Whats the problem?
The Element FLX-3711b TV is the same unit as several model of Polaroid and Visco TVs. They are all made by the same company just labeled fr different brands. The flashing power light is a very common problem and is caused by a failure of the power supply board. The capacitors on the board short out and this causes the board to not power up correctly. Here is a link to a repair guide for the Visco TV that is the same as the Element FLX-3711B so the information will be the same for both units. The repair guide shows the parts that will need to be replaced on the power supply board to rebuild it.
I hope this helps you out.
BuddyMc
Jul 10, 2012 | Televison & Video
My poloroid will power on but no picture
The Polaroid 3700 has a know issue with the power supply board. Here is a link to a repair guide showing how to remove and repair the power supply board and it should get you back watching TV in no time.
I hope it helps, if so please rate my solution.
BuddyMc
Feb 12, 2012 | Televison & Video
My poloroid 3700 flatscreen will turn on but no picture
known issue witht he power supply board in this model. Here is a link to a repair guide that should get you back going again.
I hope this helps, if so please rate our solution.
BuddyMc
Screen isn't blue when you turn on its white
The most common cause of white screen and no picture problems on this unit is a failure of the power supply board. Here is a repair guide with full dis-assembly and repair instructions that should be able to get you back going again. This guide is for the Visco TVs but the boards are the same as the Polaroid model
I hope this helps, if so please rate my solution.
BuddyMc
Dec 25, 2011 | Polaroid FLM-323B Television
No power on tv after i shut uit down
This model is know for having power supply issues. We have a step by step repair guide posted on our web site at http://www.ccl-la.com/blog/index.php/visco-vsc-37v1-no-picture-lets-repair-it/ If you can solder then you can repair your TV, if you don't want to do the repair yourself we do offer a repair service. If you want us to do the repair on your TV you can send the whole unit or remove and send just the power supply board. You can setup a service request at: http://www.ccl-la.com/blog/index.php/service-request-form/
BuddyMc
Feb 06, 2011 | Polaroid FLM-3732 Television
TV was working fine till Friday 29 Jan 11. Went to turn it on screen was dark blue,but sound was on, after about 10min the screen went to bright blue then the picture came on. Saturday the same thing,...
The problem you are having is the power supply in the TV is failing. When you try to power the unit on you get on power or a slow turn on. It also can explain the problem of not running at full 1080p resolution because the higher the resolution the no power is required to operate the TV. Check out the article that explains the problem and how to repair it.
BuddyMc
Jan 30, 2011 | Element Electronics FLX3711B 37 in. LCD TV
Tv will not turn on. power light flashing red and blue. june@thecellulitesolution.us
This model uses the same power supply that is found in many of the Polaroid TVs. The board is model MLT070AX. The failure you are having is a common problem with this board. The repair is easy if you can solder. Check out this link to an article about how to do the repair.
BuddyMc
Jan 16, 2011 | Element Electronics FLX3711B 37 in. LCD TV
I have a Visco VSC-37V1 TV and it has sound but not Video. I found the c112 and c113 caps damaged and I replaced those but still same problem. is it related with somethig like plastic that was over the...
CHECK YOUR INVETER PANEL ON THE BACK OF SCREEN AND CHECK THESE SURROUNDING CAPS AND IF THESE SUPPLY THE INVERTER POWER CABLE CAPS GONE MAY HAVE BLOWN SURFACE MOUNT FUSES ON INVETER PANEL
Aug 25, 2010 | Televison & Video
Televison & Video Logo
230 people viewed this question
Top Televison & Video Experts
Electro Med Services...
