Question about HP Photosmart 3180 All-In-One Printer
My printer has eaten about 15-20 pages of copy paper all at once.  Is there a release button to get these out?
  • geezilye Apr 10, 2009
    I had the same problem and cleared out the paper from the back...maybe a bit too hard....now I have two intact looking parts that fell out of it when I turned it over. One appears to be a dog leg with 3 holes in it, the other is a u shaped spring clip that looks like a "stirrup". Can I fix this myself, or should I just go buy a new one?
    Novelist:
  • 180 Answers
The only thing I have ever done is power it off and slowly pull the batch out in the direction that has the most sticking out of it already. Sorry. It IS a pain but shouldn't damage your printer. If you like my solution, please rate me as it helps me out, too.
Posted on Jan 17, 2009
Get paper jam message, paper is marked at the begining of the sheet but not jammed. When select copy button ,there is no paper jam problem, only when print command is used to print a document
Please follow this instructions to resolve your issue.
Solution # 1 Power cycle the printer
  1. Turn off the printer
  2. Unplug the power cable at the back of the printer
  3. Wait for at least 1min.
  4. Plug the power cable again
  5. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If you still having that error message, please proceed to the next step.
Solution #2 Clear any jams on the printer itself
  1. Turn off the printer.
  2. Please make sure that you will not take out any jammed papers in front of the printer, it can cause a mechanical damage on the printer.
  3. At the back of the printer, take out the access door.
  4. Clear any jammed papers, please make sure to clear the rollers.
Solution #3 Please make sure that the carriage will moves freely
  2. Open the cartridge access door
  3. Disconnect the power cable at the back of the printer.
  4. Check for any paper or other object that might restrict the carriage movement.
  5. Reach inside the product through the cartridge access door, and then manually move the carriage.
  6. Remove any paper or objects you find that restrict the movement of the carriage.
  7. Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left, and then to the right.
  8. Close the cartridge access door.
  9. Reconnect the power cable to the rear of the product.
  10. Press the power button to turn on the printer.
  11. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If your still having issues with it you need to contact HP to have your printer replace, if your printer is still in warranty you don't need to pay for anything, but if the printer is out of warranty charges may apply. 1800-474-6836
Good luck :)
Feb 17, 2011 | HP Photosmart C5180 All-In-One InkJet...
Prints half pager
* Does the same issue persist while making a copy from the unit?
* Does the unit prints self test page properly? Steps are given below:
  1. Make sure the printer is loaded with unused white paper.
  2. Press and hold Cancel on the printer control panel.
  3. Press Start Color Copy .
  4. Release both buttons. The self-test page prints.
Apr 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
Why can't it print more than one page at the time
You could try to clean the paper feed roller. Please follow these instructions from Canon support: (copy and paste this link into the location bar of your browser)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11865
Type question: "How do I clean the paper feed roller"
Click "Search" button. Review solution.
Dec 05, 2009 | Canon PIXMA MP540 All-In-One InkJet...
Scanner won't make copies
Maybe this will hellp others with this, if it's an output issue vs. scnaning, or those w/related Copy problem. I could not Copy without the message about Incorrect Paper Size. I finally found this link which solved that problem AND one of the paper feeding in poorly and at an angle which preceded the error msg by a week, resulted in angled prints on the page.
http://h30434.www3.hp.com/t5/Other-printing-questions/HP-6180-Will-not-copy-gives-quot-paper-mismatch-quot-error/td-p/5026
You may have an issue with your "spot sensor" and it needs to be calibrated.
Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
display.
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
Jul 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
Button sequence for head test (to look for banding)
Turn the printer off.
Load a sheet of white laser paper.
Press and hold the "Power" & "Ready/FF" buttons at the same time.
Release the "Power" button, and keep pressing the Ready/FF" button.
Right after you release the "Power" button, count 4 seconds, and release the Ready/FF" button.
Immediately, press and release the "Ready/FF" button one last time.
The printer should start printing a series of letters, numbers, horizontal lines and a black solid bar at the bottom of the sheet.
Once this test page is completed, turn the printer off to stop the test.
Feb 06, 2009 | Alps MD 1300 Thermal Printer
Paper error
I hope that this can help someone else as it has taken me all day to fix this issue on a C6180 all-in-one machine. I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
http://h10025.www1.hp.com
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
on the unit.
display.
It is one of the rare times that HP chat has fixed my printer at no cost and instantly. Here is a full transcript describing my issue and the HP chat solution:
Nov 11, 2008 | Office Equipment & Supplies
Hp officejet g85 all in one
- try to unplug the power cord of the printer
- do the semi full reset
- press and hold the # and 6 keys
- and while holding the 2 buttons replug the power cord of the printer.
- do not release the two buttons yet
- wait for the printer to starts up
- if it turn off, release the two buttons
- then it will appear the smei-NVM reset
note: this can only be done once.
Jul 24, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
HP Photosmart 3180 All-In-One Printer Logo
47 people viewed this question
Ben Johnson
