Question about KitchenAid 24 in. KUDS25SH Built-in Dishwasher
Water leaking from front
There is water dripping from the front of the unit when it is running. We had this problem a few years ago and called a repair man. I believe he replaced a bushing under the lower 4 arm sweep.
I had the same problem. Repairman replaced flat gasket on the sump cover. Also replaced lower arm and that helped too.
Posted on Mar 11, 2009
Leaking roof
You need to call a roofer to install some metal flashing pieces. That will create a metal channel for the water to flow down instead of through your roof. Look in the Yellow Pages of your local phone book.
Dec 30, 2013 | Computers & Internet
My hampton bay air conditioner has started leaking badly after running it lfor a few hours, from the front right side
For window mount units, the unit must slope towards the outside. Water is a normal byproduct of refrigeration, like condensation on a glass of ice water.... Volume of water is not an issue, water dripping inside is. All water is intended to go outside, via unit slope.
Jun 28, 2011 | Hampton Bay Heating & Cooling
Reliance 501 - purchased house a few years ago don't know how old it is - water is dripping from bottom near plate can feel a small rectagular hole with what seems a small piece of metal in the middle -...
unfortunately not, if the tank is leaking from the casing, it needs to be replaced. i would suggest, if your not paying water tax, you can run the tank for as long as you like, just divert the leaking water into a floor drain. but i do highly recommend getting a new tank. that drip can turn into a flood in a matter of days, all depending how bad the inner wall has corroded.
Jun 20, 2010 | Water Heaters
Dripping air conditoner
The "drip pan" is actually the entire base srround of the unit. There are two critical things you must confirm 1) is the unit angled back to the outside(you need water to flow away from the inside) and 2) there may be a plug/obstruction in the outer casing where the water is intended to drain from. You should check to see if either or both of these conditions exsist.
Aug 19, 2009 | Heating & Cooling
Front loading washer smells of mold maybe leaking water
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 24, 2009 | Kenmore 44072 Front Load Washer
Water leaking at front of condensor ( inside)unit.
sounds like there might be a blockage in the condensate pan that is not letting all the water drain through the condensate line. if you can access this area try to clean all the debris out
Jun 12, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Leak on a kenmore washer front load,do not have any trap in front
Apr 05, 2009 | Kenmore 44102 Front Load Washer
Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking water
It sounds as though the collection pail is not installed correctly, or the hose fitting cap is loose. Make sure that the pail is seated correctly & the cap is tight. Inspect the bottom for rust perforation, too, although this is a long shot. If this fails, then the cold coil may have broken away from it's mount, & is dripping in the wrong place. Inspection with the cover off will reveal any misalignment or broken components. Repair as required.
Jul 17, 2007 | Maytag M7DH45B2A Dehumidifier
KitchenAid 24 in. KUDS25SH Built-in Dishwasher Logo
213 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
