Question about Gateway MT3705 Notebook
No video after upgrading ram
I have a Gateway MT3705 and when I took out the 2X512 ram cards and put in 1X2GB card the screen went blank even though there was still power to the laptop.
    President:
  • 2,110 Answers
It is a memory frequency mismatch problem..
try to use a 533 Mhz Ram
Posted on Jan 02, 2009
    President:
  • 1,179 Answers
Did you accidently unseat the video card? Doublecheck to see if you completely seated the RAM and make sure you installed the correct RAM for your motherboard. Hope this helps.
Can I upgrade the video card on a Gateway E4300 to work with Shader 3 graphics (Eve Online)? Or do I have to buy a new computer?
You only really need to upgrade the video card and the PSU (most video cards need more power than what most companies like dell and gateway provide.). So no need to buy a new computer.
Mar 22, 2011 | Computers & Internet
Will a newer monitor work with my older 2.4ghz cpu
Upgrading a monitor does not require uparading the RAM or the video card on your computer unless you want to run graphic intensive video games.
Mar 20, 2010 | Dell Computers & Internet
Upgraded RAM, added USB port card at rear panel ... now no worko
Try reseating the RAM. If the computer won't even post it's probably a RAM problem. I worked on a machine about a year ago that took almost two days to get the RAM to seat properly. It was doing the same thing worked when it wanted to. I finally used the end of my BIC lighter to beat it in. You can try to reinstall the old RAM to see if the RAM is the problem or try installing it one stick at a time.
Jun 27, 2009 | Acer Aspire T310 PC Desktop
Cannot see the bios screen
I would try removing, the cd drive,hardrives out so all you have connected is the processor, and ram. If two sticks dont work try one. Try this as a starting point too see if you get a display signal from the monitor, and the bios. Also try putting in a video card in the pci or agp if the on board video isnt working.
Jun 20, 2009 | Gateway MT3705 Notebook
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Jun 10, 2009 | Gateway GT4024 PC Desktop
My Screen freezes then goes blank
I had already done the things that your expert suggested. This morning I purchased a new web cam but the same problem occurred. I took my computer back to the shop where I had just had a new motherboard, graphics card, processor and RAM put into my computer. They managed to solve the problem as it was the problem with 'frame rates per second' that the graphics card was set at. It was on 60 but should be on 85fps. What he did was Rt Click on desktop, > properties, > settings, > advanced > monitor to change the settings. Now problem is solved.
Apr 12, 2009 | Genius VideoCAM Trek Webcam
I only get a blank screen when I plug in my notebook
first of all check brihtness control of your screen was adjusted properly and fied with sufficent level.
if ok
then check RAM slot and re fixed it properly.
if stil you have the problem chek disply card mother boadrd and of laptop unit.
Nov 12, 2008 | Gateway MT3705 Notebook
Can't upgrade to 2GB RAM
I just installed 2 1gb chips in my mt3705 and it works perfect  so it might be a problem with your hardware.
Aug 16, 2008 | Gateway MT3705 Notebook
Blank screen
I just installed a geforce 6200 with heatsink, no fan, in my computer. Fry's is having a sale and for $20 after rebate, how could I go wrong? Upon first installation, the computer failed to boot.
THE FIX
Discovered modern computers will not even atempt to boot if the power supply is below the minimum requirement for the video card's recommended wattage. More proof that over-powered supplies are not an absolute necessity. I upgraded to 250w from the onboard 180w and it fired up. The rest was disabling the integrated video which i found out was compatible with geforce 5200 level of operations.
My system:
Dell Opti-plex GX260, cut to bare minimum since it was from a commercial business with 1G RAM after upgrade.
May 15, 2008 | XFX GeForce 6200 Graphic Card
Memory Problems for a Gateway Mx3215 Laptop
There are two different memory modules for that series.You can determine which you need by the chipset for you machine.If you have a Via VN800 Chipset You need the 1024MB-DDR333, 333MHz, PC2700, 200p SODIMM, 2.5v. If you have the NVIDIA nForce 410 Chipset The you need the 1024MB-533MHz DDR2-533 PC2-4200, 200p SODIMM, 1.8v Hope this clears up your problem
Sep 29, 2007 | Gateway MX3215 Notebook
Gateway MT3705 Notebook Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
