Question about Frigidaire GPDB698SSBK Dishwasher
No power to dishwasher
Hi there i have a real problem i was givin a frigidaire dishwasher a fairly new one, anyway the power cord was cut so i installed a new one. well i went to plug it in and turn it on and nothing happened. i do not have the water supply hose hooked up to the hot water yet will that cause the machine not to come on?
    President:
  • 1,462 Answers
Depends on the sequence. many, but not all, dishwashers start with drain to get rid of the slops. if yours starts with fill, then no water supply will prevent progress.(you should be able to hear a low hum which is the valve energised) check also that the door is closing properly and latching. better to use cold water fill not hot
Posted on May 09, 2007
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Apr 24, 2015 | Frigidaire 24 in. FDB635RF Built-in...
The green light says hold to lock. does not go out. can help turn off plz
Hi friend, thank you for your post!
I understand that the green light for your lock on your Frigidaire dishwasher is not turning off. I see your question is labeled under the model number GSB5712BC based off the design of that control panel you should be able to hold down the power dry button and the lock light should turn off.
If that does not correct the issue I would perform a reset on your dishwasher. You can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes. I hope this is helpful. -Matt
Sep 29, 2014 | Frigidaire 24 in. GSB5712BC Gallery...
Accidentally cut the power chord. what should I do?
get some tape and splice it back to gether. wire nuts would be best .. just make certain your connections are tight and well taped.
Jul 14, 2011 | Frigidaire FAM157S1A Air Conditioner
My dishwasher is liking water.I am under the warranty. What should I do?
Sorry but your post is a bit confusing. You have 'Problem with the Frigidaire Affinity ATF7000ES Front Load Washer' as the title but then go on to say 'My dishwasher is liking water'!
Anyway whichever it is, and I presume it is your washing machine, you say it is still under guarantee so clearly you should invoke that guarantee anyway. No-one else should touch it.
Firm advice ;-0)
John C
Feb 16, 2011 | Frigidaire Affinity ATF7000ES Front Load...
My frigidaire gallery series dishwasher wont start and the lights are flashing. whats wrong?
I would cut the power to it for a full 5 minutes and see if it resets itself???????
Feb 10, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
When the dishwasher reaches the dry cycle it pops real loud and throws the breaker what causes that.please need some advice
THERE IS A HEATING ELEMENT IN THE BOTTOM OF YOUR DISHWASHER WHEN IT GOES TO DRY IT TURNS ON JUST LIKE YOUR ELECTRIC OVEN DOES THEN GETS RED HOT AND DRY DISHES RUB YOUR HANDS ALONG THE TUBULAR TUBE AT BOTTOM OF THE INSIDE OF YOUR DISHWASHER AND LOOK FOR ANY HOLES IN IT ANYWAY LONG STORY SHORT IT IS YOUR HEATING ELEMENT OR THE WIRES CONNECTED TO IT
Jan 24, 2011 | Frigidaire Dishwashers
Someone cut off cord.Iwant to wire on new cord in proper place
If you remove the bottom panel of the dishwasher below the door right at the floor you will see on the right hand side, a metal box with a philips head screw holding the side of the box dowm. If you remove this screw you will see the electrical connections that you can wire this pig tail to properly
Good luck hope this helped you some
Dave
Feb 19, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Mineral deposits on heating element of dishwasher
There is a chemical you can buy that is a dishwasher cleaner that should do it. Wal-Mart or an appliance store should have it. If it is bad, you may have to do it several times. Ultimately you may need a new element if it is real bad.
Jul 01, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Plug at end of power cord for kenmore freestading dishwasher
heres a part number for a power cord 8566201, it costs about $50.. the same cord you can purchase at the big hardware store chains, home depot or Lowes, a heavy duty extension cord, with one end cut off, will be a fine sustitute and probly only $10 tops.. just buy a real thick extension cord
Dec 19, 2008 | Kenmore 17459 Free-standing Dishwasher
Squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Jul 13, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire GPDB698SSBK Dishwasher Logo
136 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
