Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
How do i open hanns g monitor?
I want to take the back off of it how do i open it?
    Problem Solver:
  • 15 Answers
#1 Remove the stand mount off the back of the monitor
#2 Remove the 4 screws in the corners of the monitors
#3 The monitor is now only held together with builtin plastic claw clips. They are connected to the back piece and hook onto the face piece. Use a flat object, I use a small screwdriver, to ress against the clip at the seam of the monitor. There are 3 clips down each short side, and 4 on the top and bottom. You can see a tiny marker showing each clip location at the seam. So press against the clip and gently pry the two pieces open holding it slightly open until you can spring the next clip....and so on, on each clip until it is open.
#4 once open remove the 4 lugs at the video connectors
#5 remove the two sheet metal screws.
#6 sit back realizing those clips hold the plastic together so well that screw are just overkill after that. :P
Posted on Jan 11, 2009
  • webvetter Aug 27, 2011
    Found a guitar pick a useful tool in disconnecting plastic claw clips. They are soft enough to not scratch or mar the plastic but stiff enough to shift the claws out of the connector.
M0r0n answer, there were no screws in the four corners. Chech this model... http://www.hannsg.com/PH/EN/Products/LCD%20Monitors/Common.aspx?productId=297
Posted on Mar 20, 2016
How to open Hanns G 28" monitor.
3 screws across top and 2 in lower images?q=tbn:and9gcszcucatuwbsigg82atflilcifasvtk3ai5_wt5czzf6sn7tgq_0q3 screws across to and 2 in lower corners
if this helps please take time to rate
Feb 01, 2013 | Hanns.G Corporation HW Computers &...
How to get rid of main menu on my hanns-g hw173d that keeps on popping. help me to solve this please
It's not a very good solution, but you can open the monitor and disconnect the button-panels plug on the mainboard. Afterwards the buttons don't work any more (surprise) but the control panel disappears.
Feb 07, 2012 | Hanns.G Corporation HW Computers &...
My backlight is out and i can not find parts to replace it is there a catalogue?
HANNS-G will more likely to tell you to replace the broken on if it is not under warranty or give you high repair estimate.
http://www.hannsg.com/us/en/Repair.aspx
try: http://www.shopjimmy.com/computers/power-supply-unit-vp-799-from-hanns-g-hw173d.htm
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Hannspree HANNS-G 19" Widescreen Monitor
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
May 15, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Flashing green LED on my Hanns-G HX191D
Common problems on monitors are due to capacitors in the power supply/inverter circuits failed, you need to open it up and look inside for caps with bulging top/seal first and post back what you see so we can guide you further, see failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 17, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
My Hanns Monitor keeps going to a green screen and telling me that I have no signal. I have unplugged everything and plugged it back in and it keeps doing the same thing.
change your montior and plug another monitor to check if it is doing the same problem, if it is not working then check your cpu, if is is working then reservice your lcd, if it is cheap..
Oct 25, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Help make speakers work
raggedyan184 -
You can find the driver for your monitor here:
http://www.howtodrivers.com/model501390.html
(You will have to enter in the numbers shown above the "Download" button in order to download, security measure for the site)
The following instructions (from the site) are also listed for installation:
Step-by-step guide for install HANNS.G HU171D driver.
1. Download file for HANNS.G HU171D from our site, save it on your computer and unzip.
2. Connect your HANNS.G HU171D to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new HANNS.G HU171D on Lcd monitors category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the Hanns.gdriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new HANNS.G HU171D in Lcd monitors inside device manager.
Hope this helps!
-- RT
PS - If this was useful, don't forget to vote!
Sep 08, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
Thin red line down the middle of my 22in Hanns-G LCD monitor
Hi..there,
It's seems you got a busted panel. Repaied gonna cost you a bundles... Just get a new one instead. But you can bouble checked by open the back cover and look for any lose cable from the AD board... Try unplugged the cable with a wide connector and look for any bended pins... Have a nice day!
Oct 10, 2008 | Hanns.G Corporation HU-196DP LCD Monitor
Hanns 17" LCD MONITOR
internal power supply failure,the AC power supply that powers the backlight fails every time you turn it on. Unfortunatly electronic repair is costly, A new monitor is cheaper.
Dec 25, 2007 | Hanns.G Corporation HU-196DP LCD Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
3,197 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
