Question about Dell Dimension 2400 PC Desktop
I have a dell dimesion l700cx. with windows 2000. i removed the cd rom an replaced it with a working dvd rom pioneer pidvd-115lh. it will not recognize the drive.i have tried all the jumper selections also. no icon in my computer , system, or hardware. it will open an close the tray. i thought it would find it automatic. i also don't have a disc with a driver. the case only has one tray. dell didn't leave an extra space. can someone help?
  • gholt35 Jan 02, 2009
    i tried every jumper selection.
    Habit-Forming:
  • 36 Answers
I'll bet it's a jumper problem. You'll have to remove the drive and set it to master...
Posted on Jan 02, 2009
  • sonofspy Jan 02, 2009
    Don't need a driver for a CDROM :)
    Ok now going after less likely...
    Bad IDE cable. Swap with known good one.
    Driver problem with Secondary IDE channel. Open Device manager and look for
    problems with IDE/Atapi listings.
    Bad Secondary IDE channel on Motherboard. To test you
    need an IDE cable with two plugs. Use Primary IDE channel
    (the one your hard drive is plugged into)
    Set CDROM to slave, HDD to Master or Cable Select. System
    will be slow but see if it can see your CD-ROM...
    Best Regards,
    sonofspy
My dell inspiron 5620 wont go further a black error recovery screen
Shut down, unplug, remove battery, plug in, reboot, Try a system restore/recovery. If that fails, place a repair desk in the DVD/CD rom and reboot from DVD/CD rom, try a repair my computer first. Your MBR is missing or your HDD needs replacing. Is the HDD LED blinking at start of machine? Open the machine and reseat the HDD and memory mods. If that fails, remove HDD and test, replace if necessary. You didn't mention your OS? Windows XP? This may help: http://pcsupport.about.com/od/windowsxp/f/download-windows-xp.htm
Dec 17, 2012 | Dell Inspiron 1200 Notebook
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    I re-installed windows and low level formatted the hard drive, and now the bios won't recognize the cd rom drive. I also ran the bios utility that comes with dell... what can I do to fix this problem. I...
    Even if you don't have driver for CD-DVD ROM with the Operating System,your BIOS must recognize the CD ROM.Set the BIOS to Default setting and check it recognise now.Check if you have disable anything related to CD ROM in your BIOS. Remove your CD Rom and place it again and check.
    Drive light comes because of power supply to the CD-ROM.
    If nothing works,Download the firmware update
    Here is the download link
    ftp://ftp.us.dell.com/rmsd/R104295.EXE
    Jan 04, 2010 | Dell Inspiron 1000 Notebook
    Toshiba Satellite P205D-S7479 Drivers for DVD-ROM
    Download new driver files of pioneer dvd drive fron internet.
    Apr 17, 2009 | Toshiba Satellite P205D-S7479 Notebook
    Will not recognize dvd rom
    Try going to add hardware in your control panel and have the dvd-drives' driver disk on hand.
    What are your computers specs?
    Jan 02, 2009 | Dell Dimension 2400 PC Desktop
    Blue screen
    According to the Microsoft Help and Support
    CAUSE loadTOCNode(1, 'cause'); This issue may occur if your CD-ROM is failing or is not supported.
    RESOLUTION loadTOCNode(1, 'resolution'); To resolve this issue: 1. Make sure that your Windows 2000 CD-ROM is clean and is not scratched. 2. If you have more than one CD-ROM drive, run Windows 2000 Setup from the other drive. 3. If these steps do not resolve the issue, you may have to replace your CD-ROM drive.
    Jul 04, 2008 | Dell Dimension 1100 PC Desktop
    DVD works but not regular CD ROM
    try frimware update for it from site ok pioneer.com ok
    Feb 07, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
    CD/DVD rom. CD part - does not work
    Inside your DVD rom is two heads I believe they are diamond both do the same things which is to read them. The CD head is poked (Broken). Try cleaning it with the proper solution. If its no go then the latter I am afraid stands!.
    Sep 24, 2007 | Dell Latitude C400 Notebook
    DVD & CD drives not recognized after uninstall Nero
    plain reinstallation of windows won't solve the problem, either you edit your registry to clean it up of all the nero entries or to install windows in clean mode, I mean, you need to reformat or remove windows completely first fron your system.
    Apr 22, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
    Dvd-r/cd-rom automatically ejects
    My Dvd-r/cd-rom automatically ejects. Please help!
    Justis
    Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
    Dell Dimension 2400 PC Desktop Logo
    Alun Cox
