Question about HP OfficeJet 7410 All-In-One InkJet Printer
On the LCD display. It shows the HP sign and the line below seams to be looking for the wireless signal. The off button does not work. acts like its stuck or frozon
  • markk636 Jan 12, 2009
    Yes, it did the trick. Thank you!
First unplug the printer ...Turn it around and take off the dark gray piece at the back by simply squeezing both sides of it and pulling.... Then take the two chrome screws off. Use a wrench with the funny looking tip to get t off,not a screwdriver,that will not work ! Ok,at the top of the motherboard on the top far left you will see a black coated set of wires. Remove this simply by tugging on it a little ! Wala ! Put everything back together and wait about 15 seconds after the intial power up to start printing good as new !!!!
Posted on Jan 12, 2009
  • 218 Answers
Mine did this a few weeks ago. The printer wouldn't turn off and it wouldn't get past that screen you describe. I found the thread on fixya where Maggix described how to unplug the wireless card inside the back of the printer. It kills the wireless but lets the printer resume normal operation otherwise. Apparently this is a pretty common problem with this model, but HP has not offered any help. Here's a link to the other thread - scroll down to the posting by Maggix
http://www.fixya.com/support/t648531-hp_7410_all_in_one
Posted on Jan 02, 2009
HP Dv7-1130us LCD screen displaying vertical blue line
the actuall screen LCD is bad.
in most cases.
supper common failure.. 2008 PC.
see page 31 , part 5 here. bingo, change that out.
there are 2 types used, only your full PC part number on
the service tag show this, post that and we go to the HP parts surfer and look it up.
http://h10032.www1.hp.com/ctg/Manual/c01918142
Sep 28, 2017 | HP Pavilion dv7-1130us laptop
Problem With the Sharp TV LC-32SB23U 32in LCD TV Serial No# 810825838
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 25, 2017 | Sharp LC-32SB23U 32 in. LCD TV
No screen showing up
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 21, 2010 | HP Computers & Internet
Sign comes up "osd Main controls locked" then a few seconds later "osd Main controls unlocked". I can carry on working behind the signs as they flash on and off but it's really irritating! i can't find...
guest, Problem may exist internally on the units "switch-mode-power-supply/ccfl inverter supply printed circuit board. When very, very STRANGE things start to show-up on the lcd screen that shouldn't be there, the first place I as a technician would look would be the SMPS/CCFL inverter board. If your unit acts same way when connected to different pc, or if a "known good" monitor works well with your pc, then you will need to have unit serviced by a cold-cathode-fluorescent lamp back-lit lcd monitor technician! It's that or you will need to visit YOUTUBE and see if DIY repair is in your future. Do some reading in my or "buddymc" , "budmrtn" and other techs fixya profiles here on fixya for more info. Above all else, remember this!!! Your CCFL back-lit lcd monitor isn't any different than any other brand in it's basic design and operation!!! Just do some reading to understand why so many lcd monitors fail in the field. If this response has been of some use then do a return comment so all other users can read it. Bye for now. 12fixlouie
May 19, 2010 | Philips 150S4FB 15" LCD Monitor
Where do I find the button to start the Wi-fi ?
As far as I know - the wireless button is on the left of the power button (the middle one)
If I remember corectly, the button should have three "modes" tap once - bluetooth, tap twice - wifi, tap three times - both.
But that could be just my memory acting up and there could be only one mode (on/off) in which case - check if the wireless is enabled in the system settings and/or BIOS.
Nov 09, 2009 | HP Compaq nx7010 Notebook
My epson LCD only shows a blue NO SIGNAL screen???
you just need to enable the 2nd monitor in display properties, right click on desktop and select properties then settings and right click on the 2nd display select attach.
or look at the keyboard press FN and look at the F1/f12 keys, one of them will turn the external display on or swap between outputs.
Jun 03, 2009 | Dell InspironTM 1501 Notebook
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
Chris
May 26, 2009 | Compaq 2710p Tablet PC
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
HP OfficeJet 7410 All-In-One InkJet Printer Logo
60 people viewed this question
Ben Johnson
