Question about Canon PowerShot A410 Digital Camera
Batteries not working
The camera is always on low battery. I have tried many batteries and even new photo batteries are not working.
  • hillamanda Jan 02, 2009
    Thanks for the help!
  • Canon Master
  • 4,738 Answers
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jan 02, 2009
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Yashica com
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is to low, according to NiMH or alkaline batteries.
Jan 03, 2014 | Cameras
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
My camera indicates that the batteries are low and won't power on. But, when I put new batteries in, it still indicates low battery. What can I do?
Chances are that you are not using CR-V3 camera batteries in your *ist DL. I have tried 2400mAh NiMH rechargable batteries and brand new alkaline batteries in an attempt to save money.
Neither lasted anywhere near as long as the CR-V3 batteries!
While you may be paying $15-$20 for two CR-V3 batteries, they last a LONG time!
One of the advantages of DSLRs (and digital cameras in general) is that you save money by no longer buying film and paying for developing/prints. But, even at $20 for two CR-V3 batteries, I save money! I am able to take several hundred photos on a pair of batteries (I think the manual says 500 ) instead of $10-$15 ($2-$7 for film $8 dev/print) for every 24-36 photos!
May 09, 2010 | Pentax *ist DL Digital Camera
Power / batteries
This is a common problem...sometimes you have to turn it on a couple of times.
Mar 17, 2010 | Pentax *ist DL Digital Camera
Canon a590 always low battery with new battey
Don't use regular alkaline batteries (even though you can...) It's a pain to splurge for the more expensive lithium or photo-specific batteries, but they do last. I take A LOT of pictures with my A590, and can usually get several hundred shots out of a set of good batteries. Try Energizer's web site for a coupon, sometimes they have them available.
Nov 02, 2009 | Canon PowerShot A590 IS Digital Camera
Whenever i am trying to take photos it's showing battery is low.
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Mar 27, 2009 | Canon PowerShot A590 IS Digital Camera
Olympus Camedia C-2020 Zoom - always reads low battery and then "dies"
Safe way - Try using brand new and fully charged NiMh.
Not for novice - Battery contact points may need cleaning. Use contact cleaner with a cotton swab.
Do not try - Spraying contact cleaner or WD-40 in battery compartment.
Last option - Service center.
Mar 08, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Low battery message, sent back to canon to repair and still having same problem..can i send back yet again. where to? or can i get a new one.
I had this same problem. I tried this procedure and it seems to have worked so far:
1. run a set of batteries down in the camera so the voltage is so low the camera won't even power up fully.
2. put some cheap (non-alkaline) batteries in and run these down.
3. get some hi-power alkaline batteries (the kind that are marketed as 'photo' batteries or similar, they do cost more) and put these in. Hopefully the 'low battery' indicator has now been reset.
This worked for me.
Nov 15, 2007 | Canon PowerShot A520 Digital Camera
Battery display low indication and switch off even new batteries placed
Dear Camera User, I am by no means a professional when it comes to these matters. However, I do have the same camera as you, and currently have the same problem. Other users with the same camera have also apparently had the same problem as us. I have not gotten a chance to try this yet, but I read that if you keep the camera on the video feature for a while, and maybe even try recording some video, the camera will finally power up properly and not have to shut down all the time. According to the user who suggested this, his camera worked ever since that incident. So it is very possible that this may be the solution, or at least, one of them. Good luck to you...and to me (I have yet to try it).
Mar 14, 2007 | Canon PowerShot A95 Digital Camera
Canon PowerShot A410 Digital Camera Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
