Question about True 598-TSSU608ADA SandwichSalad Unit 155 cuft
Thermostat wont shut off unit
My cooler was only working if thermostat was set at 9 the highest setting so i replaced the thermostat new one came with a capillary wire that i just laid on top of evaporater coil now the unit wont stop cooling evenat the lowest setting it goes down to 20 degrees
  • traptourists May 10, 2009
    I have a wider unit. 72" wide. I have not altered the thermostat but have a similar problem in that at setting 1 the unit will freeze water. At setting 0 (off), the fans inside the unit do not shut off. The only way to shut them off is to unplug the unit. It doesn't get down to 20 degrees but it is way too cold at the warmest setting.
  • 30 Answers
These units are bad about that. you have to mount the cap sensor in the small tube that runs thourgh the evaporator for proper operation. laying on top of the coil does not let the thermostat sense properly.
Posted on Mar 07, 2009
What's the highest temperature I should be seeing if my dial is set to 1?
If the thermostat has a control on it, you can perhaps decalibrate it so that the unit shuts off at a higher temperature than normal.
Aug 19, 2015 | True GDM-47 Refrigerator
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
Aug 03, 2013 | True Freezer GDM-49RF
Ice on the back wall; temperature went from 58 degrees to 34 degrees; had to shut off regrigerator
hi,
Wine cabinets work off of cycle defrost, so in order to built frost your temperature sensors are not working properly. I would look for corrosion on or in connections to be the fault or problem. Sensors report information to control unit and thats there only job. Its the control unit that dictates function. Look for corrosion to be the problem, clean connection and seal with RTV when connection a corrected.
Good Luck
Sep 10, 2011 | Transtherm Ermitage Wine Cooler
My newly installed Broan-NuTone attic fan worked fine for two days. Now it wont turn off, even though the temperature has dropped well (40 degrees)below the setting(100 degrees).
Hi. The most likly cause of this type problem is the thermostat. Check the thermostat housing is it hot to the touch, is it close to a heat soarse, suchas, a motor or flu pipe for a water heater. If the thermostat has a adjustable heat range setting try setting it to the lowest setting if this shuts the unit off the calibration of the unit may not be set right. If the unit is new this should be covered under warranty.
Jun 12, 2011 | Broan-NuTone ATTIC FAN THERMOSTAT CONTROL
I have a TRUE model # GDM-26 s/n 1-3521660 it keeps freezing our drinks inside, we have the temp turned down all the way to 1 and still freezes what could it be? Thought it might be the thermostat!! ...
I would say it has to be a bad thermostat. Generally I set these on 5 and they work fine. If it were a refrigerant problem the coil might freeze up but the drinks would not. Changing them can be a DIY project if you can get the thermostat.
Not fun the first time. Unplug the unit. There will be a plate with two screws that the thermostat is mounted to either on the right side or right front of the coil cover. Remove the two screws and pull the plate and thermostat down in one piece. Unplug the two wires from the stat and remove the plate from the stat making sure to note which way the plate and thermostat are oriented. The thin capillary from the stat runs up to the back of the coil. You have to reach your hand into the opening created by removing the plate and feel your way to the capillary entrance at the coil. You may be able to just see it through the hole. Make a good mental note of its position in there and pull the old capillary out. Measure how deep the capillary was in there and try to get that far in with the new one. I generally put a little piece of tape on the new capillary about where I want it to stop at the coil. You just want to make sure the capillary is clear of any wires and doesn't rub against anything in its routing. Reinstall is reverse of uninstall.
Dec 08, 2010 | True GDM-26 Refrigerator
The blower on the cooler stays on, won't cut out.
Possible that the thermostat is not working, ry reducing the control down to see if the cut off takes place.
It there is no action, shut offfor 8 hours and check witha lower settings. If the unit goes on , then you have to check the thermostat and control for fault.
Sep 24, 2010 | Hamilton Beach Water Cooler with Storage...
Setting are set on 9 and my drinks are still exploding.
Possible that the thermostat control is not reacting to the setting.
so you must check if there is any break or replace the unit.
Sep 13, 2010 | True GDM-7 Beverage Cooler
True 598-TSSU608ADA SandwichSalad Unit 155 cuft Logo
161 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a True Refrigerator Expert? Answer questions, earn points and help others
