Question about Kenmore Microwave Ovens
Kemore elite microwave cycles on and off when warming
Following starting the microwave it runs for about 1 second and then stops for 1 second and then repeats this cycle.
    Problem Solver:
  • 13 Answers
Heat element faulty
Posted on Jan 02, 2009
Not realy...Kenmore Elite microwave runs 3 seconds then stops. All other functions work ok. Model 790.80363310
Not familiar with That Kenmore elite model. But with the symptoms I would bet your unit may have an inverter, which is the power source for the part that puts out the microwave energy the Magnetron to run, If that is the case it could be a bad inverter AND a bad magnetron. If the unit isn't anything really special to you I would recommend replacing it as the repair will be quite expensive
Nov 01, 2017 | Microwave Ovens
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
LG microwave intermittently runs
I would try troubleshooting the "defrost circuit". The behavior sounds like the microwave is cooking in the defrost mode, where it actively cooks then stops allowing the food to rotate and the heat to spread then actively cooking again.
Nov 06, 2013 | Microwave Ovens
Kenmore elite microwave model 665.61682101
This indicates a microprocessor ic control board problem, professional services recommended.
Mar 12, 2012 | Microwave Ovens
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Kemore Microwave Hood Combination
I HAVE KENMORE 665/61629 LIGHT STAYS ON. AND DO NOT COOKS. AND THE FAN DOES NOT WORK.
Jan 05, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Sharp mdl R-1870 convection microwave runs for 1 min
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo.
We have the service manual and have uploaded it to our site:
http://www.microwavedisplay.com/r1870_r1871_sm.pdf
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Jun 07, 2008 | Panasonic NN-S254BF Microwave Oven
Microwave cycles off
Does this happen just at the full power microwave cook setting?
Have you tried defrosting and doe sit do it on this setting? Does it run any longer in defrost mode?
Dec 02, 2007 | Microwave Ovens
Whirpool GH9185XL problem
GH918 4xLQ-1 Microwave
Runs for a few seconds, stops, and displays F7.
I've lost my manuel. Thank you!
Robin Newell
1702 Dover Circle
Salina, Ks. 67401
(785)827-6185
newell_robin@yahoo.com
Oct 30, 2007 | Whirlpool GH9185XL Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
