Question about GE EasyCam Webcam
Short cord I would like a longer cord or an extension cord
  • 416 Answers
You can buy on in your local computer store.
Posted on Jan 02, 2009
How do I access the cable connection point of my gas cooktop cir60xs3. The lead is too short to reach the power outlet. Hence, I need to replace this with a longer lead.
buy an appliance extension cord and use that .or have an electrician come tp put an outlet close to your appliance .
Nov 08, 2016 | Cooktops
Need an extension power cord for the TG5632
You can get up to a 25ft silver satin line cord for phone, or even an extensine cord. Or contact the manufactor about a longer cord.
Feb 05, 2014 | Panasonic KX-TG5632 Phone
Stack cable isn't long enough
You only have 2 options, 1 is to get a service person to come and fit a longer cordset or 2, use an extension cord
Mar 10, 2012 | Washing Machines
I need to buy a longer cord for my PA system system on my shuttle bus...the microphone has the following on it: Executive series 100 CB68A
Mike - it would probably help if you provide the name and model of the PA amplifier too... but even so:
It is doubtful that you'll be able to simply buy an "extension cord" to place between the end of the existing mic cord and the PA's mic jack. You could probably have a new, longer cord to replace the current short cord on your mic fairly easily. Since this would require soldering and use of special sheilded cables, you should probably have it done professionally. Just about any commercial or business radio shop should be able to swap the cord for one as long as you need.
I hope this helps.
Sep 23, 2010 | Garmin Rino 130 (14 Channels) 2-Way Radio
Power cord on my dryer to short to reach installed outlet. can i get an extension cord?
Never ever use an extension cord with any major appliance. You can however, purchase a longer cord (exact same, just longer) at your local hardware store and install it directly to the machine. Anyone who can install a ceiling fan could do this for you. It's pretty simple. You could also remove the one that is on the machine and bring it with you to make sure you get the exact same wire (just longer). :-)
Hope this info was helpful to you. Good luck!
Jan 29, 2010 | GE DBSR453EBWW Electric Dryer
I have a CH WL611701AJ compressor. The motor starts and runs for approx 15-20 seconds before blowing breaker. I have replaced both capacitors, still blows breaker. Removed piston to allow motor to...
This may seem a bit simplistic but how are you hooked up to the outlet? Are you using an extension cord or is the compressor plugged in only using the supplied power cord?
If you are using an extension cord then you are going to pop the breaker every time you use it. Infact the manual states
"Never use an extension cord with this product. Use additional air hose instead of an extension cord to avoid power loss and
permanent motor damage. Use of an extension cord voids the warranty."
Air compressors don't like extension cords.
It simply draws to much for an extension cord to handle.
Depending on whether or not your warranty is out there is a simple solution. Find the biggest gauge extension cord you can
If your not using an extension cord and it's ran in the past where it's plugged in now then check the circuit because there must be new draw on the breaker
You said the breaker is 20amp. correct? The compressor should be run on a breaker dedicated to the compressor only.
Even though you should use a longer hose instead of a longer power cord you can get away with it. But forget about wire gauge size you need to think wire diameter. The extension cord I made for my compressor is approximately 3/4" thick. That is the only way I was able to use an extension cord on mine. A good place to get that size cable is a boat supply store. The cable used for shore power on boats works.
Hope this helps but if not please let me know and I'll try and help anyway I can to solve your problem.
Nov 15, 2009 | Campbell Hausfeld 28 - Gallon Air...
Black and decker edger overheats and shuts off
Use a better extension cord. Buy a extension cord with 12 gauge wire. The longer the cord, the more electrical resistance there is, which causes heat. Therefore use the smallest length of cord possible.
Sep 19, 2009 | Black & Decker Le750 Lawn Edger
I need to move the power cord from floor to ceiling
I would recomend you purchase a "heavy duty" (12 guage) short extension cord for appliances. You could remove the face cover and modify the unit so the cord goes up but I don't think it will be much longer nor will it be as safe. The cord has a moulded gromet mad onto it so you may only be able to move it to the side. You would have to make a similar mount on the unit (cutting metal and plastic parts to hold the cord properly. The short HD cord will not cause any loss in the units operation,warranty or unit life.
Aug 04, 2009 | LG Art Cool LA121HNP Split System Air...
GFCI cord not long enough
Standard extention cords are made for light draw applications like lamps and T.V.s. They are not heavy enough for the power that your A/C will draw. You can get an appliance extention cord that is made to handle heavier load such as you A/C. Most hareware stores carry them.
Jul 20, 2009 | Frigidaire FAC126P1 wall/window Air...
My compessor wont start.
ALWAYS USE LARGE GAUGE CORDS FOR COMPRESSORS. LOOK FOR RESET BUTTONS OR THERMAL OVERLOAD BUTTON ON MOTOR. DID IT TRIP BREAKER OR GFI OUTLET?
Feb 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
GE EasyCam Webcam Logo
20 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
