Question about Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Ford f350 reverse sensing system broke
I have a 2002 Ford f350 with the Reverse Sensing System (RSS), a couple months ago it stopped working. The switch on the dash used to enabld/disable the RSS remains in the "OFF" posistion continuously. All sensors in the bumper are in good condition, nothing unusual happened to trigger the malfunction. It literally worked one minute, then did'nt the next. Pressing the switch does nothing, it should auto enable when in reverse, and manually disabled with the dash switch if desired. Any and all suggestions would be greatly appreciated. Thank you dcsx3@msn.com
  • 1 more comment
  • dmsracing Feb 19, 2009
    My backup sensors on my 2001 F350 4x4 also have stopped working. I checked the fuses but none were blown. The dash control also stays in the off position and will not activate the sensors and will not turn on.
  • Anonymous Mar 13, 2009
    I will atemp to diagnose today
    same problem
    will get back to you
  • crossdmj May 06, 2009
    i recently purchased a 06 f-250. The back up sensors quit working about 6 months after I purchased it. The off light does not even come on. The system acts as it has no power. I checked all fuses in the truck and they are good. I am probably going to take it to the dealer soon.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 4894 Answers
SOURCE: How do I get the code to disable security system
TOYOTA codes are virtually impossible to obtain for free from anywhere on the Internet as access is required to the original factory database.
A few of the older ones are hardwired codes and the only place I know  who may be able to help is here
www.ukbookshelf.co.uk
If not, or you are in a rush , it might be quicker to try your Main Toyota Dealer or take it into a Decode Service
Posted on Oct 21, 2009
motor1258
  • 6674 Answers
SOURCE: Reverse lights and license plate light dont work
Try link below, may point you in right direction, but you'll have to scroll down & find what you need. Otherwise I'd start from bumper with test light & work my way back toward front harness, after all fuses, plugs etc been checked.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152800610de
Posted on Dec 12, 2008
  • 10 Answers
SOURCE: Reverse causes fuse for instrumental cluster to blow
Yes there is a reverse light back up switch located on the side of the transmission it will be the only 2 wires going to the tranny. There might be a short in the switch itself or the power wire to switch might have a bare spot where it might be grounding out on the vehicle somewhere.
Posted on Jan 19, 2009
SOURCE: Power windows and locks don't work properly
This is a common problem especially on the first gen 100series (1998-2000), the problem is in the master switch panel in the driver door, it is very rarely the relay, you could try and open the individual switches for a clean out and re-assemble, but its better to go to the breakers yard and get another unit, or a brand new one from the dealer ( expensive!!!).
The unit is designed to unlock the door automatically if you leave the key in the ignition and try and lock the door manually, the problem seems to stem from this function. however its mostly faulty panels units.
Newer cruisers dont have seem to have this issue iwth faulty switch panels.
Posted on Mar 28, 2009
dj_relly999
  • 4070 Answers
SOURCE: camry 2002 speed sensor
try replacing the fuel cervo... this maybe the cause of faulty run. a backyard auto technician can replace this without charging you much. hope this helps
Posted on Feb 02, 2010
Motion sensor
No, the rear sensing system won't signal if you are in any gear except reverse. The wiring for the module is connected so that it turns on when you put the car in reverse. (This assumes the sensors haven't failed. If they are dirty, they can sometimes signal when an object isn't there.) Some newer cars have blind spot monitors that indicate an object approaching from behind and to the side; these don't indicate an object directly behind the car.
I hope this helps.
Nov 10, 2013 | 2005 Ford Freestyle
For my 2003 ford windstar I have a fuse that keeps blowing, any ideas what system is most likely causing it to blow multiple times?
its a bit hard to say but if you remove the plugs on the devices one by one you would find the culprit. anything with heat in the word i would start with as they are a main drain and so would the door actuator as they high voltage use. the rest are low voltage compared to them mentioned.
Jul 10, 2017 | 2003 Ford Windstar
I have a 2006 explorer with the rear sensing system RSS my warning does not work and there is a warning on the dash stating to check rear backup system? The fuse should be good as my heated seat and 4x4...
Have the RSS module checked for DTC'S - diagnostic trouble code's . That should always be the first step . An it is
Reverse sensing system Parking Aid The parking aid system consists of the:
  • parking aid sensors
  • parking aid speaker
  • parking aid module
The parking aid system is activated when the parking aid module receives a network messages from the instrument cluster indicating that the vehicle is in reverse. The parking aid system sounds a warning to alert the driver of stationary objects near the rear bumper when REVERSE is selected. The parking aid system assists the driver in detecting certain objects while the vehicle moves in reverse at speeds less than 4.8 km/h (3 mph). The parking aid system may not detect angular or moving objects.
  1. Visual Inspection Chart Electrical
    • Smart junction box (SJB) fuse 18 (10A)
    • Circuitry
    • Connector(s)
    • Parking aid sensors
    • Parking aid speaker
    • Parking aid module
Do you know what DTC'S are .
Parking Aid Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1299 Power Supply Sensor Circuit Short to Ground Parking Aid Module Go To Pinpoint Test C . B1342 ECU is Faulted Parking Aid Module CLEAR the DTCs. REPEAT the parking aid module self-test. If DTC B1342 is retrieved again, INSTALL a new parking aid module. REFER to Parking Aid Module in this section. CLEAR all DTCs. REPEAT the self-test. B2477 Module Configuration Failure Parking Aid Module REFER to Section 418-01 . C1699 Left Rear Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1700 Left Rear Sensor Circuit Failure or Blockage Parking Aid Module Go To Pinpoint Test C . C1701 Left Rear Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1702 Right Rear Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1703 Right Rear Sensor Circuit Failure or Blockage Parking Aid Module Go To Pinpoint Test C . C1704 Right Rear Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1705 Left Rear Center Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1706 Left Rear Center Sensor Circuit Failure Parking Aid Module Go To Pinpoint Test D . C1707 Left Rear Center Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1708 Right Rear Center Sensor Circuit Short to Battery Parking Aid Module Go To Pinpoint Test D . C1709 Right Rear Center Sensor Circuit Failure Parking Aid Module Go To Pinpoint Test C . C1710 Right Rear Center Sensor Circuit Fault Parking Aid Module Go To Pinpoint Test E . C1742 Rear Sounder Circuit Failure Parking Aid Module Go To Pinpoint Test F . C1743 Rear Sounder Circuit Short to Battery Parking Aid Module Go To Pinpoint Test F . Your best bet , take it to a qualified repair shop . Ford
Jan 02, 2018 | Ford Explorer Cars & Trucks
2004 ford freestar in reverse the alarm sounds with nothing behind van
The alarm will sound while in reverse if it senses a problem with the reverse sensing system.
Mar 13, 2011 | Ford Freestar Cars & Trucks
Reverse sensor not working on 2005 Ford Freestar. The "off" indicator stays illuminated on dash control even if you hit button to cut on/off. Have checked all related fuses and they are all OK....
You have a bad reverse sensor or cable. My freestar got "gently" hit from behind and it damaged one of the 5 sensors, the (RSS) Reverse sensing system controller wants to see all 5 sensors at start up of the vehicle, if it does not, then it shuts it's self off. Else the RSS controller is damaged.
Jan 05, 2011 | 2005 Ford Freestar
Ford windstar reverse parking , replaced sensors
You have the infamous Reverse Sensing System (RSS) problem. You can search the internet and find various "fixes", but nothing approaching plug and play. Ford has an elaborate troubleshooting procedure using special test equipment.
Oct 27, 2017 | Ford Windstar Cars & Trucks
I have a 1994 Ford F350 pickup 7.3 diesel, what's wrong with my truck that I put the D works normal but when I reverse turns off the engine could be very strong?
Hi,is the electrical connector for your trailer intact? They often get damaged and when you select reverse can cause a short through the ignition system.
Jul 19, 2009 | 1993 Ford F350
Reverse Sensing System doesn't sound
To test the speaker touch the wire terminal a 9 volt battery tester, make this by soldering wires to any 9 volt battery, then touch momentarly the battery leads to the speaker, the cone will move and make a slight pooping noise.
Oct 16, 2008 | 2005 Ford F-150
Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
1,697 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
