Question about IBM ThinkPad 600E 2645 Notebook
PROBLEM WITH ERRORS HARD DRIVE DEV-017 ERR 81- FRU 6010 APRECIATE
HI, I have a IBM 600E 2645 4u..I.m having a problem getting back into win,s 98.I know part or all of the problem has to do with the hard drive
.In the area where it checks the whole sys. individualy,the only place it showed a problem was the hard drive where it showed these errors. DEV 017-ERR 81- AND FRU 6010.IT MENTIONED IF THIS PAGE KEEPS SHOWING disable bios memory options such as caching or shadowing.Problem is file partmgr. sys.page fault in nonpaged area.I don,t know how to do this.This show,s up after win,s has loaded and ready to open.
With out a CD in these # show in top left corner,1990302,1990305
I though F8 was where safe mode was but it don,t show it.
I WOULD APRECIATE ANY HELP WITH THIS ,AND I THANK YOU IN ADVANCE.TONY
  • IBM Master
  • 32,281 Answers
As you boot up the computer, keep on pressing the F8 key, you will be able to get into the Windows Startup Menu and be able to select Safe menu.
You most likely have a problem with a bad block in the page swap file area.
You may still not get Windows to open, and basically your need to format the hard disk and this will lock out the bad blocks and then you can install Windows again.
This also indicated your hard disk is wearing out and more than likely you will get more bad blocks and this will cause further problems such as computer locking up to data file corruption and or loss files etc.
You have an old laptop (it must have come out of the ark), it is not fixing, unless you can get another hard drive very cheaply, put your money towards a new one.
Posted on Jan 02, 2009
I am trying to restore my IBM 600E Thinkpad. I
Hi blue_sky_day,
While googling on the net, I found something related to your problem at this web site: http://www.howtomendit.com/answers.php?id=12813
There are explained many things about your IBM 600E Thinkpad, you will have to read it and see if you can solve your trouble.
Yours sincerely.
Feb 09, 2010 | IBM Computers & Internet
I am getting an Error 00301 on an IBM Thinkpad Type 2645, Model 41U, 600, and it boots to a blinking character (looks like a hypen turned sideways)
I ran the diagnostics and had errors on the SystemBoard,
DEV 001, ERR 91, FRU 3610. Upon reading on other sites, it said that the battery is dead and to remove it and run the diagnostics using just the power plug. That did correct the SystemBoard error. It is still running the diagnostics. Next I will see if I can boot the system using a boot disk if necessary.
Feb 08, 2010 | Computers & Internet
ThinkPad 600 System Board error
Have you tried using the reset jumper on the motherboard? I had a PC a few months ago that I had to replace the battery in. I eventually had to use the clear CMOS jumper and the reset BIOS jumper to get the computer to load to BIOS normally. Remember, if you don't have to correct the date and time, then the BIOS has not been reset. Sometimes it is a good idea to leave the PC off and unplugged for about 10-15 minutes to let the capacitors drain down. By doing this after reseting the PC, it gives you a clean cold boot (meaning there is nothing stored and nothing has had power before a reboot).
Nov 10, 2009 | IBM (30L2872) for ThinkPad 600E 2645-55x...
IBM ThinkPad 600 Hdd error
make sure the Hdd is well connected , and hope its not an HDD failure. Might also want to check see if you didn't disconnect any other wires by changing the battery.
Feb 28, 2009 | IBM ThinkPad 600E 2645 Notebook
Screen
Probably the display driver is messed up. Best option is to reinstall the operating system.
An alternative is to have a Linux-savvy friend try to boot it up
with a Linux-live rescue CD to see if that fixes the display problem and maybe to salvage your personal data from the hard drive.
Feb 14, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM 600E 2645 won't boot from CD rom
You can go into the BIOS and change the boot order of the drive devices,change the CD as the 1st boot device.
OR
As the laptop boots up, press F12, this will allow you to select the CD as a boot device.
Dec 07, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM thinkpad 600e error - upon startup a explorer error is encountered
hi jono ......like java name
restart ur comptr, press F5 to entering safe mode
uninstalling your dispaly adapter first,
and
restart your computer again
oke
suwun , cropp
Mar 21, 2008 | IBM ThinkPad 600E 2645 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
1,578 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
