Question about Atrix PSU 500 BLU PSCI-500BLU RET (PSCI500BLU) Power Supply
Power issues on new build
Recently built a new PCI-E system. The problem is the system will ramdomly not power on. If you press the on/off on the psu and press the case power button in the wrong order it fails to power till you leave the machine to stand before you can repower it. I have seen the issue with 3 working power supplied and 2 cases, and am completely at a loss as to where to go next
  • Just Time May 11, 2007
    Basically mobo will not start once AC power has been lost, unless its left unplugged and disconnected from the psu for at least 1 hour.
    Additionally all the keyboard lights flash intermittently once power has been lost.
  • kawabuci Jul 07, 2008
    same like you
  • 56 Answers
Hey mate smart PSU next time just unplug your power cable for about 5 secs plug it back in and try
Posted on May 11, 2007
Dell optiplex 990 flashing amber light. Will not start up. Removed and or unplugged everything that can be removed or unplugged. Nothing seems to work. Purchased new power. same issue.
optiplex comes in 3 or 4 case types, and matching different mobos.
gee golly. which is it?
i hear nothing,?
if you want to guess, just do so your self , your cash that%$$
want to do testing first, say so, diagnosis? guessing is your job.
if that is what you want to do. ?
testing.
  • first off, you push the power button and the 2 fans spin do they?
  • unstated by you this super key #1 fact.
  • the manual states powerlamp flash amber why did you not say which lamp LED flashes? page 73 in your manual.
  • the 4 diagnostic LED? or ? what? page 99 powerled blinks
  • Blinking ambe POWER LED light indicates a
    problem with the system board.
  • so there you have it main board issues, when you see that it means to strip the system down to minimum system to find shorted devices, all PCs do this, all things in a PC can in fact short at any time. (fate?) so we just unplug devices, DVD drive all HDD, all SSD,
  • then unplug the video card in th PCI slot, or any card in any PCI slot of any kind, does the blinking amber end and fans run now the PSU fan must run the CPU fan must blow. do they?
  • The ram sticks pulled , and tested 1 by 1, did you do that.
  • remove all usb devices just as precaution, most usb ports have there own regulators and do no allow overloading main PSU rails. ever, but we unplug all we can, see?
  • did you bench test the PSU first>? both? using the magic jumper check. see at link below.
here is PSU checks
http://www.pcdied.com/power.html#rapid_testing
in our shop we have load bank tester for all PSU.
that burn power, and fully load PSU, but most times we dont need it.(we also have noise checks for PSU, tools)
here is mobo bad checks.
ive no idea of this PC is factory stock or not?
some folks mix parts, put dell mobo in to alien case?
but here is all ways to mess up mother boards.
http://pcdied.com/intel-magic/m.2/update-mobo.html
things not told by you.?
  1. is it still like dell made it new?
  2. are both fans dead, amazing I have to ask but are they? the fans must turn fast and actually blow air both,
  3. do you have things in PCI slots.?
  4. what wattage rating is the PSU? 200w? or 500w?
  5. ram tests (pulls and swaps)
  6. PSU bench testing? did you? with the jumper, and see fan spins and all rails to to spec voltage with any $20 dmm meter made.
did you do a coin cell reset.
remove all wires to MOBO, cept power button tiny wire conn.
remove COIN cell
push power button, this discharges all caps now.
and NVram is now erased,
now put mobo back online, power and all, and see thaT FANS RUN
AND BIOS SCREENS POP AND IF DO , select BIOS defaults now.
your RTC coin cell is 7 years old today, and is the end of life point.
so says the battery maker, consider a new one?
or measure it with DMM, 2.9v and less is bad or at the deathh knee of life. 3.3v is new voltage.
Aug 08, 2018 | Dell Computers & Internet
All lights flashing rapidly
Indicators, Codes, and Messages
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
http://support.dell.com/support/edocs/systems/pe1800/en/it/r2053c20.htm
Aug 06, 2012 | Dell PowerEdge 1800 Server
New motherboard GA-p67x-ud3-b3 no video on boot
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16)
    * For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8)
    * The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  3. 3 x PCI Express x1 slots
    (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
Apr 29, 2012 | Gigabyte Computers & Internet
I have a Dell PE2900 which is not starting. The (single) power supply has a solid green light when plugged in. When I press the on/off button, it turns green, but nothing happens; no post, no fans, no spin...
This doesnt' look like the motherboard right away. First I would try the unit with another power supply. Using a power supply tester may let you know that the unit can give power or turn on but does nto mean the PSU is able to work with a load.
Many time dell will still have the lights even though the PSU is bad. On the back of the unit when you hit the power button. There should be status messages etc that can tell you if the unit detects issues.
This manual: http://support.dell.com/support/edocs/systems/pe2900/en/hom/html/about.htm#wp1072621
will help you. Pay attention to the Power Indicator Codes and LCD Status Messages sections.
Mar 08, 2011 | Computers & Internet
Newly built system will not power up!
It seems like you have bad MOBO. I recently ordered all the stuff to build 2 new systems. Built the first one, no power, just like yours. Moved everything to the 2nd MOBO, everything worked. I did a RMA on the DOA MOBO. Got the new one and it fired right up. Sometimes you just get bad stuff.
Please don't forget to rate this solution.
Jun 09, 2009 | Gigabyte GA-8SQ800 Motherboard
Bought a Nvidia Geforce 7800 GTX 256MB Graphics card
errrr.... do you mean the 6 pin pci-e power plug and lead that normally comes off your Power supply?
You can get converters leads that change the pinout of 5.35 HDD power to 6-pin pci-e but this is usually NOT RECOMMENDED for any GTX series of GeForce.
You usually need the dedicated PCI-E RAIL (with its own PCI-E lead/connector... or even better x 2 of them) on your power supply for these builds.
Once again.... i definately do not recommend converting one of your other power outputs to run a GTX. At best it will not work.... at worst (though unlikely) you may end up damaged your shiny new GFX card.
If you do not have a 6 pin PCI-E lead and plug running directly from your power supply to run this card.... you need one. Do you happen to know the model of your current PSU?
Mar 25, 2009 | Dell nVIDIA GeForce Go 7800 GTX, (256 MB)...
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Jan 18, 2008 | ASUS P5GD1-VM Motherboard
SG33G5 & Radeon x1950 pro 512mb
sg335g5 mb. only supports 385mb video memory
Nov 11, 2007 | Shuttle (SB83G5) Barebone
Problem with new Aerocool Zero Db 620W PSU
plug it directly into the wall dont use power bar or check for 120 / 220 volt switch
Oct 08, 2007 | Aerocool PSU |ZERODBA-S620 RT...
Atrix PSU 500 BLU PSCI-500BLU RET (PSCI500BLU) Power Supply Logo
87 people viewed this question
Top Atrix Computers & Internet Experts
Alun Cox
k24674
Are you an Atrix Computer and Internet Expert? Answer questions, earn points and help others
