Question about Logitech QuickCam Communicate STX Personal Web Camera
Static in between video
Whenever i make a video, i test it out and there is static in between the vid, allowing me to only hear the first and last couple of seconds..................why is there static and how can i get rid of this to make my vid sound clear with no static cutting me off?
    President:
  • 8,637 Answers
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static.
Second reason is, if you are using a laptop and have and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Posted on Jan 31, 2009
Static and cant hear on the phone
Plug in a headset to the phone. Does the call sound normal with the headset? If so, you may have a bad speaker on the phone.
Mar 25, 2014 | Apple iPhone 5c
I couldn't hear some of the videos(avi file) that i downloaded *mediafire* here in my netbook, i tried to download the same vid. to another laptop and it work!, i can clearly hear it . And also,there a...
try to reinstall the audio driver of your computer then restart the computer. you can download the latest audio driver from your computer manufacturer's web site.
Jun 11, 2010 | Computers & Internet
My 2002 honda accord SE coupe has started to have static whenever I play any kind of music. The static is directly related to the bass. The more base, the more static. If you play hip hop or techno music,...
you need to install a filter on the power leads of the radio and the amp.  The filter in your electrical system have gone bad and your alternator is generating noise.  Have you recently done anything on the cars electrical system such as spark plugs or wires?
Mar 26, 2009 | 2002 Honda Accord
When i make a video, i hear static in between the middle of the video and can only hear the first and last couple of seconds.......how to i get rid of the static and why does it do that?
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Jan 02, 2009 | Logitech QuickCam Communicate STX Personal...
Skype crashes whenever i try to text and often when on vid chat... OS X10.5.3 Intel Pro tower DP 2.6ghz 8 gig ram  airport extreme  iChat is fine
Normal 0 After you install Skype and have it operational with your ID. Go to "TOOLS", click on "OPTIONS," Then go to "Audio Settings" and click on it. Make sure both the Microphone and Speaker's are correctly chosen. Then "make a free test call." Wait till the voice tells you to record. Then when finished talking wait for the test persons voice to insure your audio transmission is working. Then go back to options and test your video settings. Click on Video Settings and proceed to set up you video camera. Also, you can visit this site for additional information to setup video.
http://www.skype.com/help/guides/video/
Dec 30, 2008 | Apple iSight Webcam
I want help to fix my headset whith microthone.
You better use analog multitester so you can hear a static sound coming from the headseat when you going to test.If happen you can't hear a static sound the common problem is the wire is breaks or cuts,then find where the cuts is and join it so it's works again.
Hope it may helps you;
Regards;
VOTIT
Nov 28, 2008 | Audio Players & Recorders
Logitech sound problem
Jul 13, 2008 | Logitech QuickCam Express Web Camera
Recorded Video Plays back static
May 15, 2008 | Logitech QuickCam Communicate STX Personal...
Headset
There may be a few things that are wrong:
1. Your headset may be faulty.
2. You may need to configure your router.
First, make your IP address static.
If you do not know how to do this, then there is a guide here.
After that, you will need to go into your Router's Control Panel.
You can do this one of two ways:
1. Go to Start --> Run. Type in "cmd".
Once the command box opens, type in: "ipconfig /all"
Find the "Default Gateway" and paste it into your browser.
You will be prompted for a username and password, which you would have set when you installed the router.
2. Go to http://whatismyip.org and find out what your external IP address is. Copy the address, and paste it into your browser.
Once you have logged into your Router's control panel, look for "Port Forwarding" or "DMZ".
When you get onto the page, add a new record.
Use the static IP address you used earlier, and set the record to "DMZ".
[[DMZ open ALL ports on that IP address, allowing incomming and outgoing traffic to pass in and out of the computer]]
This should allow the headset to work, however if it doesn't, it may be faulty.
Jan 08, 2008 | Sony PlayStation Portable (PSP) Console
Logitech QuickCam Communicate STX Personal Web Camera Logo
138 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
