Question about SanDisk Sansa m230 MP3 Player
My headphone jack messed up and so did menu button
I got my sandisk m230 mp3 player a little while ago. then the place for the headphones started messin up like on my freinds ipod theni messed with it moving it to get it to play right,etc.after a while i took the cover off and pulled it out then the headphone jacked look ok i put it back together and tried it and it still did the same thing. i put it on my dresser and left this morning i went to turn it on and it wouldn't? could i take it to a guy at a eletronic store could he put a new headphone jack on it and fix the menu button?
  • 33 Answers
Chances are that you screwed something up when you took it apart prolly dust or a wire or somthin got hit ~Grim
Posted on Jun 06, 2007
My sandisk when you put in headphones only one
Verify that you've pushed the headphone jack all the way in. Sansas tend to have very tight headphone ports.
If not, try other headphones. If the others do the same thing, it's likely that your Sansa is damaged.
Jan 29, 2010 | SanDisk Sansa e250 MP3 Player
Headphone Jack issue Sansa View 32GB
Buy a broken one with the headphone jack intact off Ebay and switch the jacks.
Sep 08, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
SanDisk e260 mp3 player problems!
You need to unlock the device. There is a little slider button on top next to the headphone jack.
Jul 02, 2009 | SanDisk Sansa e260 MP3 Player
Sansa m230 no sound
Try cleaning the headphone socket with a tissue also Check the equalizer and see if it is set to a preset value
Jun 21, 2009 | SanDisk Sansa m230 MP3 Player
Headphones
This is a common issue with Mp3 players - the headphone jack is damaged, and must be replaced. Sansa will not sell you just a headphone jack, and there are no repair services, so the entire player must be replaced.
Jun 14, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sandisk sansa e140
U can try to contact the Sandisk Company at 800-426-6027 and they will have a solution for this problem
Jan 25, 2008 | SanDisk Sansa e140 MP3 Player
No left ear sound.
That happened to me. It is fixable, but you need to open the caseing of the mp3 player itself. what hapened was that one of the dongles connecting the jack to the main chipset lost connection. you probably bent the headphone thing too much and it released.
to open the sansa, you must take out the battery. then you should find 2 black screws near the edge of the casing. Unscrew them and take off the black plastic cover. You should see the bottom is now totally silver. Near the headphone jack there should be another screw, Unscrew it. These are the only screwes you will need to unscrew from now. Next, Pry off the screen cover to reveal the chipset. Remove the connection from the chipset to the button pad. Take a standard screwdriver and carefully pry out the chipset, revealing the headphone jack. Be sure that the 3 dongles hooking it up to the chipset are in place. Put some tape on however you like, just be sure its tight, and be sure it doesnt interfere with any of the side buttons. Then add some more tape underneith the dongle for more support (do this unless you have a sodder, then sodder the dongles back on. Put the chipset back in the casing and replace the faceplate (dont forget to connect the button pad back to the chipset), and replace the back thing. Put the battery back in and test it. If it doesnt work then add a little tin foil into the back on the dongle. It should work.
Nov 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
My headphone jack may be messed up
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Mar 28, 2007 | SanDisk Sansa c140 MP3 Player
Headphone problems
sometimes when overplugging the headphones people tend to loosen what holds it in place i suggest you insert the headphones about halfway and rotate them when and if you hear sound completely insert them but be patient
Mar 31, 2007 | SanDisk Sansa c140 MP3 Player
Mp3 ypt8x
There is a reason for the headphone jack being loose. You either repeatedly plug and unplug your headphones, or the headphone's wire is to big. Nothing else to say, sorry!
Oct 31, 2006 | Samsung YP-T8 Digital Media Player
SanDisk Sansa m230 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
